05-15-2012, 07:55 PM | #1 |
Painting the frame
Im just starting to strip and prime my frame on my 60 C10. Does anyone have suggestions as to what worked best for you?
Posted via Mobile Device |
05-15-2012, 09:36 PM | #2 |
Re: Painting the frame
First I sprayed the frame down with oven cleaner then I powered wash and scrubbed with a course scrub pad. I found they work real good. Then I sand blaster the frame with portable blaster. The primer I used was the rustoluem rusty metal primer. It covered well and cheap ($8 a can at walmart). For paint I used Rustoluem semi gloss black. Same price as the primer and covers well. I hope this helps you decide.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
05-15-2012, 10:33 PM | #3 |
Looking good barn find! Pending how much you want to spend, you could powder coat as well. Most major cities have some really good shops that specialize in this.
05-15-2012, 11:39 PM | #4 |
I am painting mine now. I am about half done. I used POR 15. I am really happy with it. This stuff hardens like a rock.
05-15-2012, 11:50 PM | #5 |
Thanks both look really great the only downside to POR 15 is that it's rather expensive and I was wondering how well the trem clad holds up?
05-16-2012, 11:40 AM | #6 |
It's Better With Nitro
The POR15 works well if the frame surface is clean. I stripped my frame largely because I did a lot of custom modifications and welding. I shot it with some left over Nason satin paint my friend had from painting someone else's frame.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
05-16-2012, 12:03 PM | #7 |
Barnfind,
What kind of sprayer did you use to spray on the primer and paint? Did you thin it at all? Thanks, Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
05-16-2012, 12:22 PM | #8 |
automotive spray gun and u have to thin it down some good luck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
