drop spindles
Hey guys I am looking for some 3 inch drop spindles for a 1983 chevy truck can any one help
Re: drop spindles
John 82 Chevy Silverado 350ci/TH350 ![]() |
Re: drop spindles
JDM do not buy lmc's. Do a search, tons of threads on this.
Posted via Mobile Device |
#4 | |
Re: drop spindles
Make sure you figure out wether or not you will have wheel clearance issues or not. Most 15s will not fit and some 16s are back spacing sensitive Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#5 | |
Re: drop spindles
i have a truck in the garage litterally sitting on the inside of 15" ralleys. so either you grind or upgrade. cheers!
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
Re: drop spindles
I had 3" drop spindle on my old C10, and ran a 15" wheel, but yes, backspace does have to be right. Too much, and they will hit. IIRC, I have 8's with a 4.5" backspace, but I am not for certain. It was a long time ago...
Let me know if I can help you out with the spindles, as we sell BellTech. - Travis |
Re: drop spindles
I have a set of DJM 3 inch drop spindles. With the factory rally wheels there is about a millionth of an inch of clearance and it is best to grind just a tiny bit off of the caliper mounting arm (upper one I believe). Works just fine then. I hate grinding metal off of suspension parts though. Works great with anything better than 15s
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
Parts and more parts
Re: drop spindles
I am running Bell Tech 3" drop spindles on my 84. Good quality
Frank |
Re: drop spindles
http://www.suspensionmax.com/
Try this site. I got the 3-5 kit from them which ended up being a 4-5 because it also came with 1" drop springs. The spindles are 194.95 plus shipping. I had to do a little grinding with the stock 15x8 rallys but it wasn't much. Really nice quality. |
Re: drop spindles
3" drops require grinding on the caliper and my weights rub on the lower control arm on a full turn. Looks cool though..lol
Re: drop spindles
I have 3" drop spindles (Bell Tech) and 6.5" truck rallyes. After I trimmed and boxed the lower control arm they still rub. From my research 7" truck rallyes or a wheel with 3.5" back space will not rub on the control arm.
Re: drop spindles
IF you run a wheel that has a backspace of 3.25" or less, then there is no worry about the rubbing. I did that for several years until I stepped up on rim size. I have not had any issue with my rims rubbing with my 3" drop spindles and I also included a 1" drop front spring that I placed with a thin spacer to actually gett 3.5" drop. You can also go to a large diameter rim and use a 17" or 18" rim for the spacing.
Frank |
Happy to be here
![]() Join Date: Mar 2000
Re: drop spindles
The best solution is to run wheels larger than 15's...
