Old 05-20-2012, 07:17 PM   #1
kcfirstbuild
Grease or oil Pilot bushing
Im about ready to put my bronze pilot bushing on my 307 just wondering if i soak it in oil or grease it. I have been told both.
kcfirstbuild is offline   Reply With Quote
Old 05-20-2012, 07:47 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Grease or oil Pilot bushing
I have always used high temp synthetic wheel bearing grease
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 05-20-2012, 07:56 PM   #3
kcfirstbuild
some one said grease plugs it up ?
Old 05-20-2012, 08:02 PM   #4
Fldawg
Fldawg's Avatar
Heres the best way, take your finger plug one end of the bushing then pour some ATF in it and take your other finger and push on the open hole, keep doing this till the trans fluid comes out , this helps with the bushing plus the output shaft of the trans. sounds crazy but works was showed this by and old mechanic when i was sixteen now i'm the old mechanic
Fldawg is offline   Reply With Quote
Old 05-20-2012, 08:36 PM   #5
Lee H
Lee H's Avatar
Soak it in ATF over night.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-20-2012, 10:23 PM   #6
kcfirstbuild
ATF - huh to many choices now - all must work huh ?
