rear fender tire clearance 49
for those of you who went pretty low. what did you do with the inner fender brace. running 275/60 top of wheel opening is at top of wheel
![]() Join Date: Mar 2007
Re: rear fender tire clearance 49
I kept mine, but I cut relief slits in them and pounded them flat against to top of the fender so that they would not internfer. I also drilled out the rivet and welded them smooth.
Obviously I did this prior to paint. I am running 20's now, but I mocked up with 275/60 15 set up with air ride and they cleared. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#3 | |
![]() Quote:
Yeah this is aired out. This is not my drive height.
Marc
What did you do to the front braces to fit the larger wheels?
Posted via Mobile Device |
#6 | |
Marc
I don't run the rear brace. I notched and reinforced the front braces.
