05-23-2012, 11:59 AM | #1 |
putting a 60-66 steering column in a 2nd series 55
Im a regular on the 60-66 board, but a buddy called yesterday and asked if a 60-66 steering column will work on his 55 second series? He doesn't like the factory column which puts the wheel up in his chest. His other option if the 60-66 column wont fit is to cut down the 55 column around 6". Can anybody tell me if it'll work or if theres another chevy/gmc that will bolt in with mild mods? Thanks
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-23-2012, 12:17 PM | #2 |
Re: putting a 60-66 steering column in a 2nd series 55
It isn't going to lower the wheel unless he is changing the steering box and shaft to begin with.
The steering shaft is a one piece solid rod on those trucks and to lower the wheel he would have to take the box apart and take the shaft to a machine shop and have it shortened the correct amount. I know what he is going through as my 48 has the stock column with a mid 70's steering wheel and the truck is chopped 4 inches and has a seat that sets a couple of inches lower than stock. |
05-23-2012, 02:03 PM | #3 |
He owns a machine shop, so the work should be easy for him. Il pass this on to him thanks.
05-23-2012, 07:14 PM | #4 |
I'll have to look when I get home but there is an article in either Custom and Classic truck or Rod & Custom or Street Rodder this month or last on shortening a column in an older truck. They used the stock top half and added the bottom half of a later model shaft but connecting the two shafts would be the same .
05-24-2012, 08:16 AM | #5 |
Ok, great. Thanks.
