Overdrive club
Newer trucks vs. Older trucks
In a recent towing with question it was brought up that a newer truck is superior to an older truck via better handling and better brakes as well as being heavier.Thoughts?
![]() Posted via Mobile Device
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
Re: Newer trucks vs. Older trucks
I've pulled our Jayco behind our 69 a couple of times. The old Chevy did ok, but the drum brakes and lack of power steering takes the fun out of it. When I pull with the GMC (duramax/allison) it makes for a much more relaxing trip. And of course there's no comparing the 350 to the Duramax. I feel very safe pulling with the Sierra. BUT, it's nice to know the old Chevy can still pull it's own weight.
Are you refering to the post where the guy is driving to TX?
Depends on how you look at it. The easy answer is yes. But of course, like most everything, 90% is the driver. The harder part is, an older vehicle could be just as good. Technology. You have disc brakes, abs, better power steering, better power brakes (I don't even have power brakes in my 68, or power steering) but those that do, ever turn a steering wheel in a brand new truck, vs one in something 20-40 years old? Turn radius is smaller on newer vehicles, they handle much better, more aerodynamic. Have a semi pass you by at 65mph with a cinder block truck, trailer, with something else big and heavy on it, possibly strong winds depending where you're driving. Also, old truck as in... parts being old? Yeah, 40 year old ball joints, steering linkage, drums, axles, diffs, drive shafts, engine/trans, bolts/screws/fastners. If your old truck was 100% restored, in working order, and updated brakes, steering, trans, it could be just about as good. It's still a cinder block on wheels though, and fanagle an older truck that takes a football field to make a u-turn, with a trailer. Depends on how you wanna look at it. MOST of that can be compensated by the driver. I plan on towing/hauling with my 68, but not till I put in a brake controller, 7-pin, power brakes (prolly do disc at the same time) and power steering. But that's cause my trucks a work truck. IF I had a 2012 Cummins or Duramax, I'd use that. But I don't. Only thing I towed with my 68 so far was a wood chipper, mostly highway for like 14 miles, and back when I was done. I CAN tow whatever with it now, but how would I feel if something failed because it wasn't more capable? Oh and weight. Heavier you are vs. your load, the better, always. PLUS length, same truck shortbed vs. longbed the longbed will always win. And like yuccales said, comfort ![]()
68 GMC C2500 - 305 V6 - 4spd |
C-10 Club Member
If your 40 year old truck was 100% restored it would still suck compared to a new modern vehicle for towing safely.
Thats not to say an old truck is bad at towing but comparing a 400hp 2012 with a 10K pound towing capacity and every safety feature in the book to a dinosar is like comparing a appple with a orange imho. There is no way I would even consider hooking up a 5K load to my 69 and rolling down the freeway at 70 with my family. My 09 silverado will do that standing on its head and get 3x the gas mileage while being quiet and safe.
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
100% A new truck is better for anything....... My truck is completely redone with the best of everything and it still does not compare to any of my toyota tundras or new chevy trucks
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Oh wait, one major downside to a newer truck...
You won't look nearly as cool towing. ![]() That has to count for something.
![]() Join Date: Oct 2005
Kinda like comparing a 67 big block Corvette convertible w/factory sidepipes and Ralph Nader hated knock offs to a new Z06 Corvette. That 67 would drive like a tank and get plain embarrassed in regards to over-all performance when compared!
BUT...... Which one has more character and is just plain cooler? Same applies to old trucks.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
What?
I would go for the newer trucks.
But, as my father just recently told me after I explained how I wanted to upgrade the brakes in my (his old burb). "I towed a travel trailer with that Suburban across the country with you and the rest of the family, and even off road in the Sierras and across the desert landscape not once did I complain". ![]() OK Dad...
Chris 1968 K20 Suburban 1972 K10 LWB PU |
50k for a new truck. Put 50k in an old truck and see.
1978 GMC K25 2002 Dodge Dakota R/T rc swb In need of some more goodies. |
Chemist under the hood...
Good point
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
I put over 35K into my 1971 C20 Longhorn and have driven it from Detroit to Los Angeles towing about 6,000 lb trailer with another 1,000 lbs in the bed. I did fine driving and towing. I have a supercharged 350/TH400/ Dana 60 running 3.55 gears. I have used my truck to tow many other things and it does fine. Of course I have some comforts like A/C, power disc brakes, power steering and brake controller.
I also have a 2003 Chevy 2500HD Duramax/Allison that I purchased brand new. I have towed a lot with this and it is still a big difference. I have towed my enclosed car hauler everywhere and a couple travel trailers. I feel much more comfortable towing my race car in my Duramax. But you still can't beat the thumbs up you get driving the old truck. |
Ridin' Dirty
Amen to that! Get what you pay for!
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#15 | |
Cruzin
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#16 | |
#17 |
I have managed just fine with my 67-72s and that's all that matters to me. I feel they are modern as anything ever needed to be. And,all the advancements on newer trucks are great until they come around and bite you in the xxx. I've never had a bad sensor or computer problems in a 67-72.
#18 | |
Newer trucks have better brakes, generally more power, 4-6 speed transmissions, stronger frames, etc... Power is nothing without brakes and suspension to control the load. You can make an old truck pass everything but a gas station with a huge trailer behind it, making it stop and control that trailer is a much larger task. I would rather hook my boss's CC/LB Duramax equipped Sierra 3500 to a trailer than my C10 any day of the week.
My dad has had a '70 F100 for going on 25 years now, and did everything he could to make it tow better (load leveling air bags, heavier springs, better tires, best trailer brake controller he could buy at the time), you could still see "the tail wag the dog" so to speak if you were following him with much of a trailer behind it. His 04 F150 with the 7 lug heavy tow package that is bone stock (Aside from transfering said brake controller) you'd almost forget there's a trailer behind it. Both half tons, both make similar HP numbers, I'd almost bet that the '70 would walk the new truck in a drag race, but it can't hold a candle to it towing. Quote:
#19 | |
![]() Here in Maryland the speed limit on interstates is 65. Back in '72 it was 70.
#20 | |
Cruzin
#21 |
![]() Join Date: Feb 2001
Interesting thread
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#22 |
Okay perhaps good brakes was a poor choice of wording, but you honestly believe that stock style brakes from 40 years ago are better than 4 wheel, anti-lock disks? I know folks survived before all these amenities, my '70 has fewer amenities than when it was new (No radio, no heater) and I drive it every day. Common sense and focusing on the task at hand while driving also used to be much more common.
#23 | |
![]() I used to not like them either. Then I had a fuseable link on my '93 Dodge burn out. I ran a piece of wire from the battery to the shutoff solenoid and jumped the starter with a screwdriver. Made it a couple hundred miles home that way. |
#24 |
![]() Join Date: Oct 2009
such an easy question.
#25 |
Old member
Great thread and some good points on both ends but it's like the Chevy VS Ford VS Dodge issue. There want be a clear winner because it all comes back to the driver him or herself.
I have a 18' utility trailer that I pull with my 08 Tahoe and don't think nothing about it loaded are unloaded it's back there and drive. Remember the lentgh and drive. My wife, son and daughter if something happen to me and they had to drive for get it it want happen never ever. They would leave the trailer and whatever was on it behind! ![]() I carry golf carts back and forth to the beach with it and run 75-80 MPH with it and it's not even back there except when I need to pass someone! U have to remember the extra lentgh to get back over and when making a turn. It's all about the driver! Oh I do pull the trailer locally with my 71 some but not offten. I didn't build it to pull a trailer. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
