Old 05-23-2012, 09:28 PM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
post your junkyard fuel tank swaps
im curious to see what guys have used on their trucks for fuel tanks to get them out of the cab, id like to relocate mine to the usual spot between the frame rails but im not so keen on shelling out 800 bucks for a tank
iv seen guys have used tanks from the square body chev suburbans are the blazer tanks the same?
post your swaps, ideas, photos lets see what you have
1972BackInBlackC10 is offline   Reply With Quote
Old 05-23-2012, 10:55 PM   #2
Flint70step
Flint70step's Avatar
Re: post your junkyard fuel tank swaps
I used the tank from a 94 GMC van in my Burb.Check out the build thread link at the bottom of my signature for pics and how I did it.Hope this helps you out.
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way)
72 Custom Deluxe Burb(Arizona truck)Nice interior
Great patina
Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668
Flint70step is offline   Reply With Quote
Old 05-23-2012, 11:25 PM   #3
1972BackInBlackC10
thanks not sure if theres any difference between the burb frame to the truck frames though
Old 05-23-2012, 11:28 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Lots of guys use late 60's/early 70's Camaro tanks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-25-2012, 01:04 AM   #5
1972BackInBlackC10
thanks leddzep
Old 05-25-2012, 04:59 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
The square body Blazer & Suburban tanks fit pretty well and many people on this board have done the swap with them.
You can even get an EFI version with the internal sump for the in-tank fuel pump to work properly.
Not very expensive either. Half the price of the 69-72 Blazer tanks most of the aftermarket parts places sell in their kits. You can get them used really easy too for next to nothing.
It holds 31 gallons too so you get a little extra range out of the deal.
There is a 40 gallon Suburban one but it is 6+" longer and may not fit very well. Haven't seen anyone use one in a 67-72 swap.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 05-25-2012, 10:44 AM   #7
RexDodge
My son picked this tank up for me at a u pull yard a few years ago. I think it is out of a blazer (s10 maybe?). I had to do some "massaging" to make it fit. As you see I notched the frame and boxed it in for the fuel filler. I made 2 straps and mounted it up to the frame. Almost looks factory from underneath...almost, till you see the 3" exhaust squeezed in there . I will be using the in tank pump with a bypass type fuel pressure regulator (with a return). I also modified the cross sill to allow clearance of the sending unit/pump. I found a totaled late 90's suburban being parted out and scavenged the fuel door and lines to the tank. The length of the filler hose and vent line where a perfect fit..score! I wanted to have 2" to the tank and a 5/8" vent to match the filler hole/vent diameter. I also mounted the door high enough to allow 8" of fall (from the filler to the tank) to assure I would have no burping while filling the tank. I really wanted to have the tail light filler but here in Oregon we don't pump our own gas. Didn't want to chance someone breaking the tail light. I think I have about $60 total invested in this swap (just counting parts).
RexDodge is offline   Reply With Quote
Old 05-25-2012, 12:56 PM   #8
Ackattack
Ackattack's Avatar
'00 Trans Am tank mounted backwards. I got it from a buddy who wrecked his T/A. I mainly used this because it has the electric fuel pump and baffling I needed for my 5.3L
Ackattack is offline   Reply With Quote
Old 05-25-2012, 04:25 PM   #9
MARKDTN
I did a Tuned-Port swap in a '71 SWB. I used an '85 S10 Blazer 2.8 tank. Had to notch the rails a bit for the filler but it fit pretty well.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-25-2012, 04:44 PM   #10
1972BackInBlackC10
good ideas and nice work, i think im going to pick up a tank from a square body burb or blazer next weekend, it looks the easiest modifying wise and im only running a carb
Old 05-28-2012, 12:53 PM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
I know there was a guy on here a few years back who used a tank from an Isuzu Trooper, I was interested as I had a very rusty Trooper with a brand new tank in it at the time but ended up selling the thing whole to someone that wanted the engine otherwise I'd have kept the tank for later.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 05-28-2012, 01:20 PM   #12
ls1c10
ls1c10's Avatar
when i got my project it had a mustage 2 fuel tank. The frame rails had to be
cut to make it fit.
ls1c10 is offline   Reply With Quote
