Old 05-27-2012, 06:06 PM   #1
tylervalo
Hood gap issues
I took the hood off an 87 Burb for my 85 K10, the side and rear gaps all line up fine, but the front is off. It looks like the hood is always popped, it's higher than the front of the fenders and theres a small gap between the grill and hood. I removed washers from under the hood latch on the core support and dropped the catch down as far as it'll go, it's better but still looks popped. Any suggestions? The previous hood did not do that.
tylervalo is offline   Reply With Quote
Old 05-27-2012, 07:42 PM   #2
grs
Re: Hood gap issues
There are two rubber hood stops on each side of the radiator support. They may need to be adjusted down.
grs is offline   Reply With Quote
Old 05-27-2012, 07:49 PM   #3
tylervalo
Re: Hood gap issues
They're both down, when I push on one side of he hold the other comes up, like it's balancing on the striker in the middle.
Old 05-27-2012, 07:54 PM   #4
grs
Re: Hood gap issues
Post some pics. Maybe someone can help.
Old 05-27-2012, 08:02 PM   #5
tylervalo
Re: Hood gap issues
Uploaded with ImageShack.us
Old 05-27-2012, 08:19 PM   #6
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Hood gap issues
The striker on the hood is not bent by chance?
You can always try to massage the latch plate down a little more with a BFH.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-27-2012, 08:24 PM   #7
tylervalo
Re: Hood gap issues
I'm starting to think my finders needs to be adjust up, the latch is as far down as it can possibly go
Old 05-27-2012, 09:20 PM   #8
RandyP
RandyP's Avatar
Re: Hood gap issues
Did you have the fenders off at the same time you replaced the hood? Bringing the fenders up will not help the gap between the hood and support. If all you did was swap hoods and your other hood fit better, I would not go messing with the fenders just yet.
Old 05-27-2012, 09:25 PM   #9
tylervalo
Re: Hood gap issues
No, I just swapped hoods didn't touch the fenders.
Old 05-27-2012, 09:33 PM   #10
rwhit57
rwhit57's Avatar
Re: Hood gap issues
I ran into the same problem with my cowl hood. I took the latch mechanism off and elongated the holes and got the hood all the way down to the grille support. I don't know if this was the right method but it worked. Mine is still far from perfect but at least it's better.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 05-27-2012, 09:41 PM   #11
tylervalo
Re: Hood gap issues
What I can't figure out is why it's bottomed out in the latch but still too high in the front.
Old 05-30-2012, 08:17 PM   #12
tylervalo
Re: Hood gap issues
I understand what your saying now, that would work.
Old 05-30-2012, 08:08 PM   #13
grs
Re: Hood gap issues
Did you get your hood lined up yet?
Old 05-30-2012, 08:16 PM   #14
tylervalo
Re: Hood gap issues
Nope :-(
