Old 05-28-2012, 08:59 PM   #1
krazy_texan
krazy_texan's Avatar
Bad rear diff leak
Well I have been noticing lately a noise coming from my rearend so today I pulled the fill plug and could not fill any fluid so I topped it off with gear oil and off I went well I get home and parked it later I look outside and see all of my gear oil is on the ground I am assuming the pinion seal thats where it looks like it has been leaking so tommorow I'm going to pull the cover check everything out and put a new pinion seal in it.
Just curious can anyone tell me what size socket I need to remove the pinion bolt on an 86 k10 10bolt rearend
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 05-28-2012, 09:26 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Bad rear diff leak
Not off hand, but make sure you mark the nut/pinion/yolk before you take the nut off.(center punch) Then when it goes back together just go past your mark by a bit to get some crush again on the sleeve.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
