Old 05-29-2012, 08:10 PM   #1
wagonslayer
exhaust pics
I need to get the exhaust done on my 65 and need some ideas on where it should exit. I'm going with dual exhaust.
wagonslayer is offline   Reply With Quote
Old 05-29-2012, 08:23 PM   #2
Indian113
Indian113's Avatar
Re: exhaust pics
Mine exit in front of the rear wheels! I don't care for mine,I'm going to go all the way to the back this winter.
Indian113 is offline   Reply With Quote
Old 05-29-2012, 08:36 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: exhaust pics
true duals dumping out the side, no cross pipe, resonators only. Kind of a commitment since you have to cut sheetmetal.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-29-2012, 08:36 PM   #4
purebred
Re: exhaust pics
Mine come out the back.
purebred is offline   Reply With Quote
Old 05-29-2012, 08:41 PM   #5
wagonslayer
Re: exhaust pics
I like that look.
Old 05-29-2012, 11:47 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Re: exhaust pics
I have turn downs at the rear axle:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-30-2012, 10:05 AM   #7
kevinc
kevinc's Avatar
Re: exhaust pics
Do you have interior resonance with the tailpipes cut at the rear axle?
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 05-30-2012, 04:08 PM   #8
Tazfink
Tazfink's Avatar
Re: exhaust pics
I prefer out the sides behind the rear tires. I would never go straight out the back, why spend the money on the exhaust if you can't hear it? Love to hear the pipes echoing off the buildings as I cruise by!!!
What size of pipes are you getting?? What engine do you have??
I would recommend:
2" to 2-1/2" Diameter pipes with "vortec" glasspacks installed backwards.
If you look inside the glasspack and you can see little "scoops" that direct the exhaust through the fiberglass sound insulation, install so that the exhaust flows by the scoops instead of flowing through the glass.
My old engine, 305 with 283 heads, stock 350 cam and 4bbl Quadrajet would rap the pipes sooo sweet!! Sounded like a jake brake on a semi...
If you took off from a stop in 2nd, lay on the throttle and crack open the four barrel (took off the choke linkage off the top flaps and adjusted the spring so the b-flys would open easier) WITH THE AIR CLEANER FLIPPED UPSIDE DOWN OF COURSE!!! Get the RPMs up to about 5000 give or take. Then completely back off the throttle and let the 3.73 gears and engine slowing you down. Sounded awesome on a small town main street with buildings on both sides.
This practice was probably not the best for an engine, and more than likely the reason it spun a rod bearing... man it was fun though!!!
"Rust does NOT look cool." - Me
"Patina is earned, not made." - Old Hot Rodder.
Cylinder Index
The Cylinder Index (or C.I.) is a measurement device in which the total number of internal combustion engine cylinders (working or non-working) owned by an individual (single-cylinder chainsaws, lawnmowers, 2-cycle, 4-cycle, multi-clinder diesels, trucks and farm tractors) are tallied. The Garage Logician who attains a C.I. in excess of his age is revered. - Joe Soucheray, Mayor of Garage Logic.
Tazfink is offline   Reply With Quote
Old 05-29-2012, 11:51 PM   #9
brap999
brap999's Avatar
Re: exhaust pics
Mine exit in front of the rear tires at a 45 degree angle, with 3 inch polished stainless steel tips. That in combination with the flowmaster, makes the engine sound bigger than the 230 that it is.
Actually, I plan on building my GTO exhaust to exit in front of the rear tires too.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 05-30-2012, 06:33 PM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
Re: exhaust pics
There is absolutely no droning in the cab on my truck. I think mainly because the exhaust hangs from the engine and the mufflers with nothing touching the frame anywhere near the cab. Also the crossover pipe on the new system cut the sound output by at least half. It was loud like a hot rod before (although still no cab resonance). Now it sounds like a 1960’s Corvette from the outside at idle and under acceleration. It still does produce an impressive exhaust note under wide open throttle however.
Much of the exhaust sound is also due to the mufflers themselves, which are Flowtech Terminators. Thy don’t seem to have a very popular following, but I’ve used them since the 1980’s and will never buy anything else unless they quit making them.
Old 05-30-2012, 07:25 PM   #11
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: exhaust pics
Show me your exhaust
http://67-72chevytrucks.com/vboard/s....php?p=5339807
side pipe exhaust anyone
http://67-72chevytrucks.com/vboard/s...d.php?t=393566
Exhaust tip through fender
http://67-72chevytrucks.com/vboard/s...d.php?t=474727
60-66 with sidepipes/lakes pipes?
http://67-72chevytrucks.com/vboard/s...d.php?t=504275
Pics Of Exhaust on 60-62 with Torsion Bars
http://67-72chevytrucks.com/vboard/s...d.php?t=502288
Lets hear some different exhaust setups on your 1960 - 1966 Chevrolet & GMC Pickups
http://67-72chevytrucks.com/vboard/s....php?p=5403062
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
