I need some help guys like urgently
Well long story short
my neighbor came over and touched my air cleaner then i remembered i needed to check where i had a air leak once i took off my air cleaner i saw gas dripping from the gas line(truck on) to carb inlet I turned the truck off and took it off replace the filter that was in the carb put some Teflon tape on the treads and put it back on Well it still was leaking bad took it off and looked in the carb to look at the treads and saw that they were stripped ![]() ![]() its a rochester 4bbl what can i do to fix this i don't really have money to buy a new carb i found out my carb was leaking like a hour ago What can i do guys? can i just use a tap and dye set and tap the treads again or should i get some of that jb weld and use that??? I hate that everything always happens at the last minute and i work tomorrow at 7 ![]() |
Square
Re: I need some help guys like urgently
Helicoil may be the fix you are looking for.
Squarebody Syndicate |
The One And Only !!!
Something like this is what you need; http://gesslerheadporting.com/gessle...e!OpenDocument
Verify if your's is 7/8 or 1" diameter, They have both sizes with different filter lengths. Anything less is a crap shoot.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
i have never seen those things restrorob put up but that looks like the easiest fix for your situation. a helicoil isnt gonna fix your problem.
any ideas i have are risky at best i personally would get the part in the link. its tempting to order one for my carb to have on hand in my jet kit box just in case.
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf. |
I've used them a couple times in the past without issue, You can likely find them at your local parts supplier as well.....
fuel eats teflon tape, thread sealer is what you want to use with fuel. I was using an AN -6 fitting on my qjet and had a leaking problem too. I had stripped threads also. I ended up using JB Weld on the threads. Have not leaked in 2+ years. I use an inline filter (actually 2) cause i knew over time of changing the on-carb filter will kill the threads.
Dino burner
Because you're short on time, I'll second restorob's suggestion of a self-tapping fuel inlet fitting.
The proper way would be to Heli-coil it, but you may not find someone in your town/city who stocks the size and style needed for a Quadrajet. |
Check your local parts store, seems I remember seeing one of those self tapping doodads in the help section. Ask the parts guy, maybe you'll get lucky and get one that actually knows something.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
Well went looking for that self tapping fitting nobody has it
Not autozone oreilys, advanced or other auto part stores I'm just going to have to jb weld it for now I guess Any certain way on applying it? Should I apply on the fitting and the inside of the carb? Once I have it screwed all the way in do I apply some on the outside? ... Posted via Mobile Device |
i applied it to the threads. When you install it will ooze out. All i did after that was clean it up a bit with my finger. to make sure it was all around the fitting, kinda like using caulking.
DarkReaper79 why did you use to filters?
Is it to keep the pressure down? My truck is not turning on I think its getting to much gas now How it use to have two filters, the one in the carb and a inline filter But now it only has the inline filter Do yall think that's the problem Posted via Mobile Device |
i used a filter before the electric pump and one before the carb. If yours is getting too much fuel you need to use a regulator. What fuel pump are you using?
http://s1105.photobucket.com/albums/...=VIDEO0045.mp4
http://s1105.photobucket.com/albums/...=VIDEO0045.mp4 This is what it is doing now do you think that is has more pressure now since i took out one of the filters? or does the carb need to be readjusted? Last edited by frog210; 06-01-2012 at 11:15 PM. Reason: trying to get the video on here |
It looks like it got some trash in it and the needle seat is stuck open, flooding it.
#15 |
it is a stock fuel pump
how is the easiest way to clean the needle with out taking the carb apart possibly? (could i blow some compressed air in their maybe dislodge it?) I was really hoping that i could just slap another inline filter and that would fix it (maybe reduced the pressure)(do i have to adjust the carb now how it dosent have one filter, maybe its trying to suck it all in?) forgot to put this in the video The first time i try to crank the engine over im pushing the gas (if i hold the gas down and crank it it will turn on but sounds horrible and dies) The second time im just turning the key |
#16 |
You could try blowing a little air in it, I would spray some some carb cleaner in it, you could also tap on the front of the carb, if this doesn't work you'll have to take it apart. If you have a stock fuel pump there should be no need to regulate pressure, it's fine, you just have carb issues. Good luck.
#17 |
But dosent the truck have to be on to spray carb cleaner in it,
Or do I spray it and let it sit for a little bit Posted via Mobile Device |
#18 |
No, use the aerosol carb cleaner with the straw thingie and spray in the fuel inlet, you might get lucky. If not the least is going to be a kit.
#19 |
Well its working now
![]() I added a foot of gas line and a second filter and it still dis the same thing Well my neighbor came over and Un screwed the little gas fitting that goes into the bigger gas fitting on the carb the one I welded on their t(because the threads had stripped) Stuck a screwdriver thru the hole in their like 3 times Screwed it back in and told me to try turning it on, push on the gas twice Vroom truck started and sounded good Maybe some of that quicksteel I had used topped it a little bit We left the truck running for like 15 minutes so I can burn out what ever was in their I just have 2 questions now My carb was smoking a little bit is that normal? I was thinking it was just burning up all that small stuff and burning up what ever carb cleaner I sprayed in their? How do you adjust theses carbs I had moved the screws thinking that would fix it, now it is idling high, it has two screws one on the left and one on the right Posted via Mobile Device |
#20 |
Bump
#21 |
![]() Join Date: Apr 2009
Be aware that the fitting in question does NOT seal on the threads, It seals on the nylon gasket between the fitting and the Carb. make sure the gasket it not cracked or split.
Often when removing and re installing the fitting the Carb gets a little dirt through , into the needle and seat. While the engine is running Lightly and I mean Lightly tap on the front half of the Carb until it stops.If that doesn't work try the following. Another tip with Carb flooding is to vise grip the suction line down at the fuel pump, Start the engine , Let it run out of fuel until it stalls. Remove the vise grips , restart the engine the quick rush of fuel back into the Carb Usually flushes out the dirt. Desert |
#22 |
What about the little bit of white smoke that smokes out the carb
after like 30 minutes on When you turn the truck off |
#23 | |
Could be a little fuel bleeding over from the Carb needle and seat. Might be a little oil bypassing the valve guides in the cylinder heads . If its running OK and only smokes after hot start up, probably OK to run. If it smokes ALL the time that's a whole different situation. Desert |
