Steering Wheel Adapter
I've recently purchased a 1965-66 Chevy Wood Wheel.. Picture below..
I'd like to put it in my 1972 C20. I've read that the 67-68 Camaro adapter works for this column, but mine has Tilt.. is there a difference in the regular and tilt adapters? Which adapter works for this wheel, and my tilt column? Thanks.. J.
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. |
Re: Steering Wheel Adapter
No one?
J.
Junior Member
Sharp wheel. I believe you are correct the mounting hub (adapter) for a 67-68 Camaro works best for our trucks. The 69 and up have a larger 4-1/8" diameter hub (larger column for integral ignition switch started that year).
I am in a similar stage in mounting my saddle colored comfort (cushion) grip wheel and have not found any information that would suggest standard and tilt columns take a different hub. How deep is that wheel? You may find this wheel you have will be quite a bit closer to the driver once you get it all mounted up.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
Thanks for the information..
And thanks for the compliment, I really prefer this wheel style to the three spoke.. But I also have a comfortgrip style out of a 72 Corvette that I was going to mount.. Not sure what I'll do with that one.. maybe put it up on Craigslist. This wheel is similar in style to the stock wheel, and I believe it's about 3.5" deep Smaller in diameter by an inch. J.
