05-31-2012, 02:23 PM | #1 |
Need Advise - Do I need a C Notch
I will be lowing my 87 swb 5/7 or 5/6 based on which hole I use in the shackle. I will be buying a Western Chassis Flip Kit and keeping a full spring pack. Then adding the 2" shackles. I've read a couple of members threads where they did not use the C Notch (BiggArmz is one). My truck has a towing package and I may have to tow a vehicle once in a great while. I'm just not sure if a Notch is absolutely necessary. Will just removing the bumb stops give me enough clearance to load or tow anything? Please let me know your experience with this.
05-31-2012, 02:42 PM | #2 |
Re: Need Advise - Do I need a C Notch
definately remove the bump stops, the axle will be very close to these still in place. with my 7 inch rear drop, i have 3.5 to 4 inches from axle to frame and a 250 lb person can jump up and down on the bump and get it to hit. granted i only have the 3 leaf pack too. im going to install the helper bags on mine to hual anything heavy or pull a trailer.
05-31-2012, 09:10 PM | #3 |
I think anything more then a flip kit will require a c notch.. But if you have a thick leaf pack it will drop you 6-7 inches.
Posted via Mobile Device |
05-31-2012, 09:11 PM | #4 |
67-72 parts collector,…
Yes.
C-notch required.
05-31-2012, 10:05 PM | #5 |
Thanks Keith-
I didn't want to take the bed off more that once. I want to freshin things up while I have the bed off, so I will notch it at the same time. Hopefully, I can still tow a car if needed with the notch. |
05-31-2012, 10:07 PM | #6 |
These 73-87 trucks had 2 different length leaf springs.
Some were 52". Some were 56". One of those will require you to notch a bed support also. (to clear the 2" drop shackle) I can't remember which length it was.
05-31-2012, 11:51 PM | #7 |
I think I'm ok. I actually have 2 inch shackles on it now with no problems. It was sitting real high stock and I had some laying around, so I just slapped em on. That's a great point though. Thanks for the heads up. I like your truck. Those are hard to find in good shape.
06-01-2012, 03:45 AM | #8 |
heres mine at ride height in the back or maybe a little higher. I was just hauling my big dirt bike around so I had some more air in the back shocks. Theres a good 3" of space before the axle hits the bumpstops. With all the air out of the back, its an 8" drop and no c-notch. Right now its about 6" lowered in the back and it wont bottom out unless you have 300lbs in the bed and hit a big bump. The only reason I;m going to c-notch it is because I am adding 2.5" drop spindles and 2" lowering blocks in the rear over the winter. Then I will be running 7.5/10 drop. Will probably have to bag the front after I do that
06-01-2012, 02:43 PM | #9 |
Great info Square_78. Thanks, how do you like those air shocks? I wonder if I can get away with just adding air shocks and if I could tow with them.
I will most likely just notch my frame and be done with mine. I think 6" to 7" is the lowest I will go in the back depending on the rake I get after I drop the fron 5" with 2.5 srings and 2.5 spindles from western chassis. Hopefully the 2.5 spindles don't cause my 15x8 rallies to rub. |
06-01-2012, 05:21 PM | #10 |
I love the air shocks. I dont know if they are designed for towing or not. But they work great when you need a little extra lift for a heavier load.
06-01-2012, 10:04 PM | #11 |
yeller
The shorter springs require the cross sill under the bed to be notched when running drop shackels
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
