Frames?????
I've gotta question about these trucks. I'm a 67 guy and dunno much about these. Are all the frames the same from 60-66. I've got a 65 truck but the frame has seen better days
1965 c10 short stepside ![]() 1967 c10 fleetside 350/350 trans (my baby) |
Re: Frames?????
`63 to `66 frames are the same...!
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Re: Frames?????
60-62 had the torsion bars in the front end
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: Frames?????
GMC are leaf sprung rear
60-66 Nut
Re: Frames?????
Also to add, the '63-'66 frames are only slightly different than the '67-'72 frames. The '67-'72 frames can be used under a '60-'66 truck with just a few changes made. Of course the easiest is to use a '63-'66 frame. Check with your local DMV to be sure you don't get in trouble with having a frame with a different VIN than the cab.
Re: Frames?????
What all needs to be changed for a 67 to 72 frame to work
60-66 Nut
Re: Frames?????
The front frame horns, the radiator support mount brackets need moved, the rear cab support mount brackets are different and/or need moved up, and the radiator lower support crossmember for the '63-'66 needs to be installed into the '67-'72 frame. I think that is it. You might send a PM to member ScotI, he has actually done the conversion.
