06-03-2012, 10:01 AM | #1 |
P30 steering box on a C60
just as the title states anyone tried this? I read on the big bolt site that the boxes were similar in the way that they operate and mount just thinking about putting power steering on "blue bob" then I could use the hydroboost. Thanks for looking and helping. Jim
06-03-2012, 12:44 PM | #2 |
Re: P30 steering box on a C60
the c30 str box is the same as the c10 box(light duty trucks) which may be light for the c60 frt end. I would check out what the medium duty trucks used for p/s boxes. they used larger ones for a reason
ron |
06-03-2012, 01:08 PM | #3 |
The question is will a P30 box fit aC60 . I know that the C box from the 10-20-30 would not work. The P30 is a different truck /chasis all together
06-03-2012, 01:29 PM | #4 |
still a one ton capacity
ron |
06-03-2012, 01:53 PM | #5 |
P30 has a rating more than a one ton. It shares some of the similaritys of the HD 3500 but the steering box is mounted similar to that of a C40-50-60 truck
06-03-2012, 01:55 PM | #6 |
And it also has a 5000# front axle if I am not mistaken if I am then I appologize
06-03-2012, 02:23 PM | #7 |
actually just checked the specs.
p20-30 4,000 lb frt c30 3500 c60 7000 those are std specs- can veri ron |
06-03-2012, 05:48 PM | #8 |
I did stop and look at a s/a c/o this morning. should have similiar strg in it. think that it is going to the scrappers pretty soon and did look at the guage panel before. all a/c guages, tach only went to 4000 though. it did have a 427 in it . must be a tall block though,
will be going by again within a couple of days . will stop and take a pic of the str box ron |
06-04-2012, 01:42 AM | #9 |
60-66 Nut
I'm not sure if it is a P30 chassis, it is a P-series though. Anyway, on the motorhomes that have the heavier duty 10 lug wheels, the steering assembly has a bellcrank in which the steering box turns the opposite direction. Just something to look out for. Otherwise I don't know if the P30 steering box will work on your C60. I would have to agree that a steering box from a later model C50-70 may be a better choice. But I do realize those may not be that easy to find in some areas.
06-04-2012, 07:46 AM | #10 |
I was just thinking of that motor home cause it is just sitting out by the shop not being used. I was gonna used the stuff off of it on my 70 projct big dually but it is stuck in park so to speak. It was to be a C60 fleetside 454T400 tilt under dash air and few other goodies but oh well
