06-03-2012, 12:38 PM | #1 |
6 lug to 5 lug swap
I have a 70 12 bolt coil spring posi rearend it has the 6 lug axles can i just change the axles & brake drums from a 5 lug rearend will they interchange ??
06-03-2012, 03:59 PM | #2 |
Re: 6 lug to 5 lug swap
You can get the front 5 lug change over from CPP or McGuaughs. They also have the rear axle kits. You will need to measure the axle length. there were 2 widths. Earlier trucks seem to have the narrow axles which are hard to find used 5 lug axles for.
06-03-2012, 07:06 PM | #3 |
so 69 -72 rearend are differant ?
06-03-2012, 07:08 PM | #4 |
Mid 70 they started using the wider width rears
1970 c-10 lwb named "heavy metal therapy" |
