06-06-2012, 05:44 PM | #1 |
700R4 Install any ideas???
I have an extra tranny lying around and i thought this might help me save some ga$. I have a 71 C20 350 and was wondering if this would work. Any help or advise would be greatly appreciated.
06-06-2012, 06:09 PM | #2 |
Junior Member
Re: 700R4 Install any ideas???
Yea it will work (your results may vary). I did it and it's been done and documented quite a bit by others. I searched this site and others on the web and found a wealth of info. Best advice I could give is do your research, homework, and get the TV cable right.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
06-06-2012, 08:04 PM | #3 |
not sure what you have for a tranny now, but the 700r4 is a different length than the th350. You will most likely need to modify the driveshaft. A worthwhile upgrade especially if you have a working converter lock. I wired mine to lock in forth gear.
06-06-2012, 08:20 PM | #4 |
If its a c20 im assuming it has either a th400 or a manual trans. If you use your truck as a truck you will regret the weaker 700r4 fairly quickly. They never put a 700r4 in a 3/4 ton from the factory for a reason.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
06-09-2012, 01:39 AM | #5 |
My old 1986 GMC 2500 came with a 700R4 from the factory. It never gave me any problems. I used the truck to pull a 26ft 18000# trailer. The truck blow its motor before the tranny ever gave me any problems. I pulled the tranny before I sent the 86 to the crusher and will be using it in my 67 when I do my motor and frame swap.
Favorite quote: "I'm sick and tired of being sick and tired BĦħ@h!" - Drunk guy in one of my accounts Rides: 67 Chevy C10 LWB Stake Bed(in bad shape) 04 Miti Endeavor AWD(wife's ride) 76 Dodge D100 Club Cab(Hand-me down from my Grandfather) Last edited by clb1024; 06-09-2012 at 01:42 AM. Reason: Add pic of tranny |
