truck is a 83 6.2 th400 4x4 burb. truck has been setting at least 2-3 years. glow plugs stay on unless unpluged fast ideal seems high and when she kicks off she will hunt and wont smooth out bring it up and runs great. cant do a road test as has no breaks yet also motor is supposed to be rebuilt. could it be the pump is not adjusted right? anythiing will help thanks, mike
Re: 6.2 hunting for idea
IIRC 83 has the old style of glow plug controller. Sounds like it's not working properly, its probably best to wire up a push button control for it....there's a lot of write ups on that. I would dump a can of seafoam in the tank and replace the fuel filters and run it for a bit and see what happens.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
#3 | |
The hunting is an injection pump wear problem, sloppy advance. Mine started to do it at low RPM light load, like 35mph on cruise in the city. It got progressively worse until finally I changed out the pump. The cold idle being high, probably all the idles are high because they turned up the idle to try to hide the worn pump hunting problem. The Seafoam may help, and you can drive it with the hunting, but the pulses aren't good for your drive train. Sooner, not later, you'll need a pump. BTW the next thing you should see is fuel dripping from the advance shaft at the bottom of the pump. A reseal kit is unlikely to fix it, usually it's worn and the pump needs rebuilding. Welcome to 6.2's, I get 23mpg mixed driving on my fully loaded 87 R10.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors Last edited by D13; 06-07-2012 at 06:43 AM. |
Moderator
![]() Join Date: Oct 2008
Updating to the newer 1990's glow controller is as easy as bypassing the early unit.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
