Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-07-2012, 12:52 PM   #1
redsled87
redsled87's Avatar
15x12 & 325/50/15 MT's
Is anyone running that wheel and tire combo? If so, I'd like to see pics because I'm thinking really hard about running them next year when I swap out rears.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 06-07-2012, 03:45 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 15x12 & 325/50/15 MT's
That might be an in between size from what most are running. I run a 16x12 wheel and Hoosier Pro Street radials on the street, which ends up being a similar size to the MTs you're asking about. I run a 15x10 wheel with a set of 315/60 - 15 MT drag radials at the track. Here's a photo of my 16x12s with the Hoosiers...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-07-2012, 05:52 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: 15x12 & 325/50/15 MT's
Front wheels: Weld Racing Draglite 90-Series Wheel 15 x 7
Rear wheels: Weld Racing Draglite 90-Series Wheel 15 x 12
Front tires: Falken Visa 912 Tires - 758 P215/65R15 96H
Rear tires: Mickey Thompson Sportsman Pro Tire, 29x15.50-15LT
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-07-2012, 09:03 PM   #4
darkhorse970
darkhorse970's Avatar
Originally Posted by vin63 View Post
I run a 16x12 wheel and Hoosier Pro Street radials on the street, which ends up being a similar size to the MTs you're asking about. Here's a photo of my 16x12s with the Hoosiers...
I love the look of this tire and wheel combo.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 06-07-2012, 08:35 PM   #5
Super73
Super73's Avatar
I am running a 15x12 with a 315/60/15 MT DR. essentially the same tire just a 30" tire vs a 28" tire. When I get home on tue I will try to get some pics for you.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-08-2012, 12:50 AM   #6
redsled87
redsled87's Avatar
Do you guys have any side shots?
60' 1.49
1/4 10.93
MPH 120
Old 06-08-2012, 12:08 PM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
im running 15x6 fronts and 15x14 rears with 31x18.5x15 MT sportsman drag radial
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-08-2012, 08:40 PM   #8
Super73
Super73's Avatar
Willie,
Doed MT call the sportsman a drag radial? I ask as I 5hink the compounds are different. In other words, I think the dr is actually softer.
Old 06-08-2012, 10:33 PM   #9
1Bad62Pro/Street
Mickey Hides:
Street:
Sportsman Pro
Sportsman S/R Radial
http://www.mickeythompsontires.com/street.php
Strip:
ET Drag
ET Drag Radial
ET Drag Sport Compact
ET Drag Jr.
ET Street
ET Street Radial
ET Street Radial II
ET Street Radial Pro
Hoosier Hides:
http://www.hoosiertire.com/
http://www.hoosiertire.com/pdfs/speccat.pdf
Coker Tire Pro-Trac Hides:
http://www.jegs.com/webapp/wcs/store...+Tire+Pro-Trac
Take one set off the front and leave 4 in the back...
Pro/Foot
Old 06-09-2012, 12:14 PM   #10
redsled87
redsled87's Avatar
Originally Posted by 1Bad62Pro/Street View Post
Mickey Hides:
Street:
Sportsman Pro
Strip:
ET Drag
ET Drag Radial
ET Drag Jr.
ET Street
ET Street Radial
ET Street Radial II
Hoosier Hides:
Pro/Foot
Pro Foot, that would be pretty darn cool! I say you try it and we'll see if it takes off!
60' 1.49
1/4 10.93
MPH 120
Old 06-08-2012, 10:50 PM   #11
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Well mine are the 315/60-15 MT ET Street d/r's...mounted on a 15x10 rally wheel with 4.5" b.s. The 1st pick shows 15x8 rallys (4" bs?) with 275/60-15 BFG's.
I need to get some different wheels with a 5.5" to 6" b.s....or even more if they're over 10" wide.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-09-2012, 12:38 PM   #12
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
I'm running that combo..... here is a pic.
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 06-10-2012, 11:31 AM   #13
redsled87
redsled87's Avatar
What brand and style wheel are you running? I originally wanted Weld Rodlites but, now I'm thinking about Centerline Convo Pro's instead.
60' 1.49
1/4 10.93
MPH 120
Old 06-10-2012, 11:40 AM   #14
limitedstreetoutlaw
Weld Draglites.
Brandon
Street Car Mafia
Old 01-21-2013, 10:00 AM   #15
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
Wink Re: 15x12 & 325/50/15 MT's
I love the looks of those tires!!
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 06-09-2012, 12:11 PM   #16
redsled87
redsled87's Avatar
68GMC, That's pretty bad a$$ looking. I've been looking at tires the last several days and, I might just go with a 15x10 and the 325/50 because, I like some sidewall bulge and I don't think I'll have it with the 15x12's. But still a 15x5 w/ a 205/75/15 and a 15x10 w/ a 325/50 will still look good and I should have to mini tub it.
60' 1.49
1/4 10.93
MPH 120
Old 06-09-2012, 12:47 PM   #17
68GMCCustom
what b.s. are those? and did you make that bed cover?
Kurt -
Old 06-09-2012, 12:52 PM   #18
limitedstreetoutlaw
7 1/2 bs......and yes its home made
Brandon
Street Car Mafia
Old 06-09-2012, 01:06 PM   #19
68GMCCustom
I like the cover, looks clean. I need to get everything tucked up under too...as you have there. These wheels only come in 4.5" or 5" bs....so I may have them modified or just replace the whole set with something else, but I still want my track tires on a separate set of rear wheels that match the main set.
Kurt -
Old 06-09-2012, 01:22 PM   #20
limitedstreetoutlaw
Brandon
Street Car Mafia
Old 06-09-2012, 10:30 PM   #21
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Once you go 12's you never turn back! lol
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 06-10-2012, 07:34 AM   #22
djracer
djracer's Avatar
We are putting that exact combo on my son's street Strip Truck. Here are a few pics.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-10-2012, 11:52 AM   #23
redsled87
redsled87's Avatar
djracer, where did you find blem M/T's and how much cheaper were they? What is the backspacing on the wheels?
60' 1.49
1/4 10.93
MPH 120
Old 06-10-2012, 05:13 PM   #24
djracer
djracer's Avatar
I bought those tires used at a big drag radial event for less than 100 for the pair. I don't remember exactly.
I don't remember the exact back spacing but its not much. We are building a narrowed 9 inch for the truck.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-10-2012, 12:29 PM   #25
68 C-10 KID
Mean Green
Dang Kevin I like the wheels you and JR picked out.
Correct me if I'm wrong. One of the great benifits to a 12" wide wheel is to help square up the tire for a better better contact patch.
AKA MEAN GREEN.
