Vacuum line
The HVAC control on my 1990 Suburban is stuck blowing air down the heater vent. I examined it closer and turns out, and I found a vacuum line that goes into the firewall that is crispy and falling apart. The vacuum line is very small like 1/8" and made out of plastic. I went to a parts store and they didn't have it. Where can I find this part?
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
Re: Vacuum line
Try to find a supplier that deals in parts for pneumatic / hydraulic systems, they usualy stock this type of hose. They are often used to connect control valves and sutch things.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
Re: Vacuum line
Ed, I don't know if they call it plastic convoluted tubing or not. Summit Racing has a bunch of tubing, but 1/4" is the smallest I saw on their web site.
When I worked in the paint shop for GM we used Parker Paraflex tubing for our air lines and they were pretty small- 1/8" or so. |
![]() Join Date: Oct 2011
Re: Vacuum line
Autozone has it in stock as I had to replace some as well.........
Re: Vacuum line
Find a heavy truck parts or repair facility and tell them your looking for 1/8 or 5/16 air line, spaghetti line
Posted via Mobile Device |
