Old 06-07-2012, 11:05 PM   #1
Jargo
How can I find out if my transmission is original
I have a 63 chevy c10 it has a Saginaw 3 spd transmission the number on it is
GM 31 3925647. Can anyone tell me when it was made?
Jargo is offline   Reply With Quote
Old 06-10-2012, 12:14 AM   #2
ray_mcavoy
Re: How can I find out if my transmission is original
Hi Jargo,
I think what you found there is the GM casting number for the transmission case.
I Googled the 3925647 and it's showing up for a Saginaw 3-speed in the 68-72 year range. That'd be the one with the 7-bolt side cover and fully synchronized forward gears.
The earlier 3-speeds (like what your 63 would have had originally) have a 4-bolt side cover and a non-synchronized 1st gear.
There should be some additional numbers stamped (not raised up cast numbers) on a small flat spot just under the edge of the side cover. Should be a letter followed by a few numbers. The letter will tell you the assembly plant (most likely an S for a Saginaw 3-spd). The following numbers tell you the month and day it was assembled. But as far as I know, there's no partial VIN or anything on these transmissions that can be used to determine their exact original application.
ray_mcavoy is offline   Reply With Quote
Old 06-10-2012, 12:31 AM   #3
Jargo
Thanks, I did not think it was original.
