Old 06-08-2012, 01:17 PM   #1
badriand
badriand's Avatar
Rear bag question?
I have a c-notch with 5 inch coils and and 2 inch blocks on back now. If I replace coils with airbag kit in place of coils will it allow me to get rear lower or be the same height. Trying to keep the back out more still has some rake to it. Thx
badriand is offline   Reply With Quote
Old 06-08-2012, 02:55 PM   #2
badriand
badriand's Avatar
Re: Rear bag question?
Sorry tryin to bring back down a little more. Didn't proof read.
Old 06-10-2012, 03:15 PM   #3
txinliner
txinliner's Avatar
not sure but the bags would allow the adjustability the springs and blocks dont.im in kinda the same boat got a 65 c10 all originall but no c notch really thinking about it though.btw freakin love the ripple caps
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 06-10-2012, 03:16 PM   #4
txinliner
txinliner's Avatar
what drop do you have in front
Old 06-11-2012, 08:45 PM   #5
badriand
badriand's Avatar
3 inch drop springs and 2.5" drop spindles
Old 06-11-2012, 10:39 PM   #6
Pro Performance
Pro Performance's Avatar
Say you go with a Slam Specialties air bag. That air bag will collapse down to just under 3", which should sit your truck down pretty low when aired out. You can measure how high your coil is now with the weight of truck on it, then the difference to 3" is how much lower it will sit aired out.
Hope this info helps.
Travis
Pro Performance is offline   Reply With Quote
Old 06-11-2012, 11:59 PM   #7
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
I will say lower since you can air it out and it will drop lower then the spring. Ride will probably be better too.
The rear is easy to do..
MOTOIMPAIRED is offline   Reply With Quote
Old 06-12-2012, 05:37 PM   #8
badriand
badriand's Avatar
thx guys for info.
Old 06-12-2012, 05:46 PM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The bags should let you bottom out in the notch.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
