Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-09-2012, 11:52 PM   #1
mightymouse
mightymouse's Avatar
reverse manual valve body
does anyone on here run reverse valve body on the steering column? i have a b+m pro stick and a bench seat and the shifter is way to low. i started to make a console but it looks crapy.. any ideals
mightymouse is offline   Reply With Quote
Old 06-10-2012, 11:56 AM   #2
redsled87
redsled87's Avatar
Re: reverse manual valve body
I would try and make a riser for your shifter. I ran a standard pattern valve body on the column for several years and it was kind of a pain. The ratchet style shifter is much better way to go imo. You don't have to worry about going into the next gear. You could always get a B&M Mega Shifter for trucks with a higher base. That's what I have and it works good.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 06-10-2012, 12:13 PM   #3
mightymouse
thanks for the info redsled87, ill check out the mega shifter, i'm thinking of trying to fab a mount off the seat frame but that would bring the cable way up off the floor . dang if you do,dang if you don't
Old 06-10-2012, 01:58 PM   #4
dbmx66
mine sat too low as well so i made this fully adjustable platform for the shifter to get it up higher. you might be able to do something similar. mine has a tci manual forward valve body.
dbmx66 is offline   Reply With Quote
Old 06-10-2012, 03:35 PM   #5
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
I also made a riser to get the shifter to were i was comfortable .
Thats a wild looking riser dbmx66.
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 06-10-2012, 05:13 PM   #6
mightymouse
thanks for the pictures guys , those are nice, im going to scrap what ive been working on today and make one similiar to yalls. heres a pic of what i wasted my time on
Old 06-10-2012, 05:18 PM   #7
djracer
djracer's Avatar
I want to put a cage in my son's truck and build a shifter mount off the dash bar. I have seen a sexy one on here that someone built.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-13-2012, 01:20 AM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
This is one that was in my Foxbody . Just to give an idea .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
