Old 06-10-2012, 09:50 PM   #1
kcfirstbuild
Glass polish ?
So i want to really clean up my new old soft ray windows and rear window. I used glass cleaner and it just doesn't cut it in some places. There are some scratches too I think i might be stuck with those and thats ok just want to get ride of the spotty areas.
I just read some posts about Bar-keep cleaner and green pad, or 0000 steel wool. What do i want to use with the steel wool, water or some kind of lubricant ?
Will any of these choices hurt the soft ray tint ?
kcfirstbuild is offline   Reply With Quote
Old 06-11-2012, 12:03 AM   #2
oldspowered67C10
Re: Glass polish ?
Ive had good luck with Bon-Ami brand sink cleaner, dont use Comet, its too abrasive. Id imagine really fine steel wool would work also, Id try it dry first and see what happens.
oldspowered67C10 is offline   Reply With Quote
Old 06-11-2012, 12:04 PM   #3
E.Furgal
Re: Glass polish ?
x2
E.Furgal is offline   Reply With Quote
Old 06-11-2012, 02:27 PM   #4
cdowns
cdowns's Avatar
Re: Glass polish ?
i use a product by mcguires called "plastix" designed for motorcycle windshields and also headlights but have found it very usefull on real glass stuff too
Old 06-11-2012, 12:25 AM   #5
Harpie
Harpie's Avatar
Re: Glass polish ?
I used a good cleaner polish and a buffer with a gray foam foam pad. The perfect it III was the one I used and worked great!!!
Harpie is offline   Reply With Quote
Old 06-11-2012, 03:20 AM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Glass polish ?
Try also a real wet magic eraser on it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-11-2012, 06:11 AM   #7
Re: Glass polish ?
This is a good question. I have never tried to polish glass and will also need to do it on my old glass going into my project truck. Also,my '85 Jimmy has scuffs on the windshield. Since this applies to all vehicles,maybe members with other years would like to see some answers. There's a message board for just this type of thing where I'm sure the best answers will be found if asked there:
http://67-72chevytrucks.com/vboard/f...splay.php?f=65
Old 06-11-2012, 06:54 AM   #8
rsavage
rsavage's Avatar
Re: Glass polish ?
In doing a little research on this. the consensus of glass professionals was that cerium oxide in a slurry and a cotton felt wheel were what they used. Here is a kit:
http://www.caswellplating.com/buffin...shing-kit.html
Haven't tried myself yet.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-11-2012, 11:08 AM   #9
redc4
redc4's Avatar
Re: Glass polish ?
I just got home from the 2012 Power Tour and found a new product by Mothers that is specifically made for this. Mothers Water Spot Remover for glass, saw them remove some NASTY waterspots from a 2000ish TransAm.....
I had to have a bottle after seeing that!
1970 C-10 Fleetside LS-x motor 700R4
redc4 is offline   Reply With Quote
Old 06-11-2012, 05:05 PM   #10
Bert W
Bert W's Avatar
Re: Glass polish ?
I have used Bon-Ami and Bar Keepers Friend, they are they same. They don't have the same abrasives that Comet and others have. Cerium Oxide may be the active ingredient in Bon-Ami. I'll have to check.
Nope! Baking soda, Feldspar, bio-degradeable cleaning agents, Soda Ash, & Limestone
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 06-12-2012, 09:34 PM   #11
kcfirstbuild
Re: Glass polish ?
Vinegar no go !
Old 06-12-2012, 09:40 PM   #12
six-T-seven
Re: Glass polish ?
a Mr. Clean Magic Eraser WILL scratch the glass. Just a heads up.
six-T-seven is offline   Reply With Quote
Old 06-13-2012, 11:49 AM   #13
Andy4639
Old member
Andy4639's Avatar
Wink Re: Glass polish ?
I've used it 3 times with plenty of water and haven't scratched the glass yet. I've even used with glass polish before as well.You just don't bare down on it like your cleaning a wall in the house with it though!
Old 06-13-2012, 01:14 PM   #14
CC69Rat
CC69Rat's Avatar
Re: Glass polish ?
Good ole Colgate works too.. and it's cheap.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-13-2012, 01:15 PM   #15
six-T-seven
Re: Glass polish ?
Glad you had good results with it, but the "cleaning" action of the eraser is the result of a micro abrasive. Abrasive as in fine sandpaper.
Old 06-18-2012, 09:33 PM   #16
kcfirstbuild
Re: Glass polish ?
My body guy had a kit from eastwood for polishing glass you made a past with this stuff and a tuff cotton ball at the end of the drill. Takes out small scratches too!!
Problem solved ! I had scratched I could feel with my finger nail, it took them down to where they were not as noticeable. THe old water spots are gone now moving to the rear window to get those spots off!!! GO East Wood !!
Old 06-18-2012, 09:47 PM   #17
70cst
70cst's Avatar
Re: Glass polish ?
Interesting thread ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-19-2012, 12:04 AM   #18
chewychevy67
Re: Glass polish ?
my back window had a gun rack over it needless to say it has some deep gouges in it. with all the technology today can't someone come up with a way to fix those. other than that the rest should polish out. done venting. will be trying these methods soon keep em coming.
chewychevy67 is offline   Reply With Quote
Old 06-19-2012, 10:20 AM   #19
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: Glass polish ?
these ideas are all good suggestions...... i too am trying to clean my re-installed glass & have very bad water spots. i was told by the glass guy that installed my front windshield that what he uses is CLR with a clean microfiber towel. the ingredients are supposed to eat away the actual "stain" of the water spot. i saw the commercial for the mothers cleaner & i am interested to see how it will actually work? i tried headlight cleaner (mcguires) and i was not impressed with it all.... basically just "shined" the glass up. definetly going to follow this one........
rodstored-72 is offline   Reply With Quote
