Old 06-13-2012, 01:16 PM   #1
Satin69
Manual Paddle valve question
Hey Guys, I need some plumbing help on the manual valves for my system. If I run one line from the tank to the switch and the other from the switch to the bag, where does the dump fit in?
Thank you for the help in advance.
1956 GMC undergoing LS Swap
Satin69 is offline   Reply With Quote
Old 06-13-2012, 01:56 PM   #2
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Manual Paddle valve question
The "dump" is in the switch itself. So when you press down on the switch, the air will be let out right there.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 06-13-2012, 03:41 PM   #3
Satin69
Thank you for that. I was thinking this had to be the case bc the system didn't come with any other valves.
I hate to seem slow here but will the switch dump it back to the tank?
Old 06-13-2012, 03:49 PM   #4
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Nope, dumps the air right out of the back of the valve into the cab. This is why it is important to regularly drain the tank, otherwise you could get some nasty condensation in the tank resulting in a mildew smell when you dump, or in an extreme case, nasty rusty water if it makes it that far.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 06-13-2012, 05:11 PM   #5
JNJchev77
Registered Cruiser
JNJchev77's Avatar
X2...
It's really a full proof set up, kinda old school I guess, but it does the job if you're not wanting to play with switches all the time.
And don't feel like your "slow", I had to learn the same way. Just ask questions, and make sure you get it right the first time.
77' Chevy SB
5.3/4l60e combo
Old 06-13-2012, 10:05 PM   #6
theastronaut
theastronaut's Avatar
Or get valves that have the exhaust port tapped to you can run exhaust lines that dump outside the cab. Should be quieter in the cab that way too.
theastronaut is online now   Reply With Quote
Old 06-14-2012, 12:46 AM   #7
LEEVON
Moderator
LEEVON's Avatar
I have two lines from the tank to the valves, tee'd into each to reduce the number of lines in, then of course 4 out. I like the simplicity and low maintenance compared to electric valves.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 06-14-2012, 11:33 PM   #8
Satin69
Cant thank you guys enough. This is a big help. I will post pics when done.
Old 06-20-2012, 11:00 PM   #9
Satin69
Worked like a charm. Thanks again everyone.
Old 06-21-2012, 11:43 AM   #10
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Pics??
77' Chevy SB
5.3/4l60e combo
