06-13-2012, 07:08 PM | #1 |
Another Lowering Question
I just bought a 65 LB and I want to use it as a Bike (Harley) Hauler. I want to lower the truck but still be able to put a bike or two in the back when necessary - what is my best bet?
06-13-2012, 08:06 PM | #2 |
Re: Another Lowering Question
Buy a trailor! I can't haul 500lbs. in the back of my stepper after dropping it with jeep springs. Honestly you can pull more than you can haul. If you buy a trailor you'll find all kinds of reasons to use it.
06-13-2012, 08:42 PM | #3 |
Give serious consideration to the Porterbuilt Stage 1 rear kit. Very economical and I've heard great things about the results.
http://www.porterbuiltfabrication.co...-1963-1972-365
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
06-14-2012, 01:09 AM | #4 |
Indian - Sound advice, I'm sure. Already have a couple of trailers that are great for hauling bikes but I'm determined to find a way to do this.
MisterC - Thanks for the suggestion, I will take a good look at Porterbuilts setup. |
06-14-2012, 10:31 AM | #5 |
Never Ending Projects
That would definitely be a need for an air bag setup in the rear at least. This way you can tailor the height to match the load.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-14-2012, 10:57 AM | #6 |
if you wanna haul DONT USE JEEP SPRINGS!! cant carry much using those springs. an air bag setup may be the thing to help you carry a bike while still having a decent ride
Posted via Mobile Device |
06-16-2012, 11:34 PM | #7 |
x3 on the airbags
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
06-17-2012, 01:08 AM | #8 |
A friend of mine used 70's El Camino air shocks to allow him to haul a harley around in his bed - He thought it was the solution!
Looking at your truck, I assume you have trailing arm suspension - At a recent show, I saw a gentlemen who used Firestone Frieghtliner cab air bags in front of the axle on the trailing arm mounted to a crossmember with a land-rover air-suspension hieght sensor, a single relay, a frieghtliner air solenoid - and a harbor freight air bottle (for filling tires) hooked to a Air-ride on board compressor. I thought the system was pretty sharp, and he told me the bags were 40 bucks at a truck salvage yard, the sensor was 5 bucks from a u-pullit, the Firestone compressor was around 50 bucks, the bottle was 14.95 on sale, and the 60 dollar solenoid was a the most expensive part - he didn't mention the cost of airline, but it was plastic air-brake stuff - so I assume he boosted it from work! It was a pretty sharp setup for 170 bucks, however it was run from s single toggle switch - Granted this system was completley home-brewed, I thought it was pretty impressive- |
06-17-2012, 02:00 PM | #9 |
@Indian113: how much lower did you get with the jeep springs? and what type of jeep did they come out of?
06-17-2012, 02:46 PM | #10 |
06-17-2012, 05:29 PM | #11 |
Thanks for all of the advice guys. I got a quote from a local Riverside Guy - two compressors and airbags all around for $1500. I am going to get a couple more quotes before I commit but everyone I have spoken to said that sounds like a good deal.
06-17-2012, 05:37 PM | #12 | |
If it's just occasionally hauling bikes, mount the bags in the rear just like swapping in lowered coils. Run some DOT .250" airline to schrader valves & add extra air when required (use a tire pressure gauge for dialing it in). Bleed the extra air out when your done just like you would if you put too much air in a tire. 2x bags, DOT air line, & 2x schraders can be done for <$300. I ran this set-up for almost 2yrs w/o issue. I only upgraded to the compressor & tank because I started using my car trailer more frequently.
06-18-2012, 02:58 AM | #13 | |
06-17-2012, 08:47 PM | #14 |
Thanks for the info @Indian113!! Starting a build of my own and wanting lower it on the cheap so this helps. Thank you tons.
