Old 06-13-2012, 10:02 PM   #1
JohnT71
My 68 Chevy journey
I have been building this 68 chevy short wide for about two years. It has taken me all over gathering parts, met lots of good people along the way. This is what we started with, when I say we I mean me and my buddy Jessie. Without his help I would have never got this far and probably quit. So ride along I will post pics every couple of days, I have several.
JohnT71 is offline   Reply With Quote
Old 06-13-2012, 10:04 PM   #2
Tinkermc
Re: My 68 Chevy journey
looks like hood could use alignment, nice starter truck
Tinkermc is offline   Reply With Quote
Old 06-13-2012, 10:31 PM   #3
JohnT71
Thanks, the hood is still out of wack but not that bad. I never tore a vehicle this far apart this is my first frame up rebuild. Put a front end from a 86 which gave me disk brakes, just had to drill one hole and it bolted up. Welded up the trailing arms and put in new bushings. The spring are 4 inch lowering springs that we got in a trade.
Old 06-17-2012, 07:44 PM   #4
JohnT71
This is how far I have come, I lack painting the bed. It has turned out pretty good, I am very proud.
Old 06-18-2012, 11:42 AM   #5
67cheby
67cheby
67cheby's Avatar
Looks great !
67cheby is offline   Reply With Quote
Old 06-18-2012, 01:40 PM   #6
67c10rustbuket
67c10rustbuket's Avatar
Hey whats up John? glad you got a build thread going! nice job on the chassis and paint, looks great. Now how about those under hood shots.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 06-18-2012, 07:43 PM   #7
JohnT71
Here is my 98 vortec 5.7, it bolted right in. Had to have the pcm reflashed to take the vats out of it. Had to use a high hump so the 4L60e trans would clear. I even took the rear end out of the 98 truck and welded perches on so it would have the same gearing and new brakes. Oh and took the inside wire harness out of the 98 and installed in the 68.
Old 06-18-2012, 07:51 PM   #8
67c10rustbuket
Looks good John, I have yet to wire and start mine (remember I have the same drivetrain) but I just finished my driver side rust so now it is time to do the front susp to get it rolling and paint the frame and then wire and fire it up. I see the relay center on the fender well but where did you put the PCM ? I would like to put it inside the cab but havent messed with untangling the wires to see if there is enough wire to move it inside. Looks like you had the same firewall harness also in the last pic.
Dan <---(my name)
Old 06-18-2012, 07:54 PM   #9
67c10rustbuket
I see you also used the 98 booster/master cyl. I considered trying this but ended up never pulling it from my donor. Was it difficult to modify it for this truck?
Dan <---(my name)
Old 06-18-2012, 08:03 PM   #10
Tinkermc
you should be proud it looks good
Old 06-18-2012, 08:07 PM   #11
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
good work...looks great!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-18-2012, 08:54 PM   #12
JohnT71
Thats is a older pic, need to get a newer one under the hood. The pcm is actually sitting right below the relay center like is was in the 98 truck, I guess I did not have it in there in that pic. Exactly the same wireing harness as you had in your pics. The master cylinder and booster are out of the same 86 truck we took the front end from. Had to extend the rod eye a little but it fit just fine. Need to bleed the brakes still have a spongy pedal.
Old 06-18-2012, 08:55 PM   #13
JohnT71
Thanks for the compliments guys!
Old 06-19-2012, 08:13 AM   #14
JohnT71
I used a gas tank from a 98 2-door S-10 blazer. Had to trim a bit to get it between the frame rails but it fit like a glove. Welded bolts and used the original supports to hold up the tank. Took the sending unit from the truck tank and shorten it to fit in the S-10 tank. I also had to move the rear crossmember back and weld it back in, worked out nice.
Old 06-19-2012, 08:01 PM   #15
JohnT71
Installed some Fatmat Rattletrap today, not completed but a good start.
Old 06-20-2012, 11:17 AM   #16
Tinkermc
lookin good, love that fat mat
Old 06-20-2012, 12:32 PM   #17
JohnT71
Tinker have you used the fatmat before, I read good reviews and bad. Just wonder how well it works. I like the way it goes down, seems like good stuff.
Old 06-20-2012, 12:39 PM   #18
bonnieclyde100
does that steering wheel have an air bag and if so will it be functional ?
bonnieclyde100 is offline   Reply With Quote
Old 06-20-2012, 12:45 PM   #19
jchav62
1962 C-10
jchav62's Avatar
Way cool project! The Vortec setup is awesome...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-20-2012, 01:05 PM   #20
JohnT71
No air bag
Old 06-20-2012, 06:06 PM   #21
Nice looking project build
Old 06-21-2012, 08:39 PM   #22
JohnT71
Vent window rebuild, used the pop rivits to put back together. Not as bad as we thought.
Old 06-21-2012, 08:43 PM   #23
JohnT71
New hood letters
Old 10-21-2012, 10:44 PM   #24
JohnT71
Painted the bed, all the block sanding made it pretty straight.
"There's a force in the universe that makes things happen; all you have to do is get in touch with it. Stop thinking, let things happen, and be the ball." -Ty Webb
Old 10-21-2012, 10:53 PM   #25
67c10rustbuket
Bed looks great John! Is that a Camaro fender i see ?
Dan <---(my name)
