Bare minimum engine wiring 78 c10
I need to get my car running because the local code enforcement likes harassing me.
Previous owner left some of the wiring there, but I dont know where to start Its a 78 c10, I put in a 91 suburban 350, converted a carb and 73-80 HEI Distributor. I believe my truck was originally V8 Any pics, especially what plug goes where would be a big help |
Re: Bare minimum engine wiring 78 c10
18436572 is the firing order. The rotor turns clockwise. You need fuel, and a power wire to the "bat" terminal on the distributor this will get you running
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Ah yes the alt needs a wire to the battery positive. And the starter needs the power from the positive Batt cable and a signal wire from the ignition to the small terminal on the starter.
If you need a wiring harness for the engine it may save you time to get one at the local wrecking yards it justs unbolts from the firewall and comes out easily
Thanks, I got lucky and I had most of the engine wiring the mostly squared away last night, except for the starter wire.
Theres 3 wires and a metal tube? power, solenoid and? |
Metal tube? I'm assuming this is the starter your talking about?
Yes this should have one large stud and twwo smaller that are signal. The signal terminal is the closestbto the block.
Part of your main harness that comes down attached to the large terminal and battery cable on the starter.
Ok, I have an 87 burb tilt column and when I hit the switch, nothing happens
Tell the local Goon Squad to "eff off". It's you're property, ain't it?
Code Enforcement Officers are the "Hall Monitors" of society. |
Wish I could.... They have given me warnings about other cars before, but if they come back,( they havent yet with me) the car has to start, move forward and back.
Try putting the small wire on the small terminal onthe solenoid see it that work. Does your dash light up at all when u turn the key forward
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
^Yep, code enforcement suck @$$, so nice to know our tax dollars are paying for them to harass us!
Posted via Mobile Device |
I wish I had a dash.. lol....
I dont have a cluster yet. The previous owner tossed everything. |
#15 |
dose it have to start by key if not just jump the starter with a momentary switch for the stupid rent a cop
1978 GMC C25 LWB ![]() |
#16 |
I want to get the column working so I can just hit a switch.
#17 |
just but it on a switch in the truck so it looks good
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
#18 |
Ok, I have power at the big terminal of the starter, at the fuse box, key makes power flow to the circuits, but I have no power at the distributor, or starter when attempting to crank?
#19 |
Any unacounted for small guage wires in the engine compartment? Probe them looking for one that goes live when you turn the key to start (crank), you may have the wrong wire hooked up to your starter.
The bat wire is probably going to the wrong terminal in the distribution block, it should have power in both start and run position. Quick and dirty work around: Run a wire to an on-off switch hidden somewhere from the battery. Connect the switched side to the bat terminal on the HEI, AND run a second wire to an MOMENTARY contact push button switch easily in reach from the drivers seat. Turn Key to Run. turn on switch. press button to start. DON"T FORGET TO TURN OFF THE SWITCH when parking, or you will 1.fry the hei coil. 2.drain your battery. Alex. Last edited by Axle; 07-01-2012 at 12:39 PM. |
#20 | |
The only thing I cant get power to is the starter. I know the starter and column are good, both came out of running trucks |
#21 | |
#22 |
are your nutral safety switch wires on if not it wont start
#23 |
#24 |
there should be two purple and two green.
#25 |
Jumper the purple wires at the neutral safety switch. If your neutral safety switch is out of adjustment you will also have a no-start.
Alex. |
