Missing rear cross member?
Hi guys
im finally trying to get my 63 c10 on the road, its going away soon to have the engine fitted but im trying to tie up all the lose ends before it leaves its dropped on lowered springs on the back and it came with a shock relocating kit, im trying to figure out where it goes and it seems like the rear cross member is missing, Any of you guys shed any light? ![]() ![]() ![]() |
60-66 Nut
Re: Missing rear cross member?
Yeah, there is supposed to be a crossmember right where the springs bolt to the frame. You really need to have some sort of crossmember there.
i thought so, can anyone help me out with a picture of theirs and perhaps some dimensions?
#4 | |
It's Better With Nitro
![]() http://www.porterbuiltfabrication.co...-for-the-pair) ![]() ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
contact porterbuilt for a crossmember. Its not expensive and do you have the panhard bracket? If not you can get one of those as well. Good luck!
HI guys, im in the uk so getting a cross member is gonna be a pain in the arse, think im going to have to fab one up.
Not at all, Porterbuilt ships. Customs won't even know what it is other than a piece of tube steel. Contact him at http://www.porterbuiltfabrication.com/ and he'll get you set up!
Look at "Tubular Replacement Crossmembers" once you get to the sight.
Never Ending Projects
Stock crossmember with relocation kit.
![]() Different truck but same setup, looking from above. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
