Old 06-15-2012, 07:03 PM   #1
F-85
65 GMC 305 V6 and 4speed clutch problems
OK well putting a new clutch in the GMC. I ordered it from Napa, but its wrong. I called all around and no one has a 11" Clutch for this setup. WTF...... The pilot bearing was wong, the clutch was wrong. Anybody have any info on this? Thanks
F-85 is offline   Reply With Quote
Old 06-15-2012, 07:12 PM   #2
j.kirn
Re: 65 GMC 305 V6 and 4speed clutch problems
The 60-66gmc.org
j.kirn is offline   Reply With Quote
Old 06-15-2012, 07:20 PM   #3
F-85
Thanks but i checked there first. No posting info on the clutch. Just the trans. Well at least i didnt find any.
Old 06-15-2012, 07:39 PM   #4
padresag
if you post and ask the question there , you will get a reply. common problem,
the parts guys don't know any better and are giving you a chevy clutch disc. you will probably have to get yours rebuilt. it has to do with the hub emerging on the flywheel side.
if you do a search on their forum there will also be a lot of info on it.
ron
padresag is offline   Reply With Quote
Old 06-15-2012, 08:16 PM   #5
jbgroby
jbgroby's Avatar
I had my clutch resurfaced in New Orleans, which seem to be the better option. You'll probally need to find an older shop that has the experance.
jbgroby is offline   Reply With Quote
Old 06-15-2012, 08:43 PM   #6
MusicMan70
MusicMan70's Avatar
Someone from the Jolly site bought from HR clutches and here's what he emailed me;
"The clutch itself worked fine, however the release bearing they sent me was wrong - I'll be sending it back. My old on was fine.
It's a 10.5" disc with an 11" pressure plate, works fine."
http://www.hrclutch.com/
I believe he paid $225 at the time.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 06-16-2012, 02:01 PM   #7
duallyjams
duallyjams's Avatar
On the GMC V6 you have to get yours rebuilt no one makes them anymore.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 06-16-2012, 04:46 PM   #8
F-85
Thanks Guys
Old 06-16-2012, 07:51 PM   #9
wc63
wc63's Avatar
im doing the same thing on my 63 305 v6. i had to go to a clutch and brake place to find what i needed. im using a t5 so my disc spline had to be 26, but the hub on the camaro was rubbing with the flywheel. the guy had to find a an early 90's pontiac clutch which was 11", had 26 spline, and a small enough hub so as to not rub with the flywheel. hope that helps
wc63 is offline   Reply With Quote
Old 06-17-2012, 11:00 AM   #10
T Herder
Here is an excellent place to start, http://www.centricparts.com/. I check there catalog for the parts and part numbers, then order them from NAPA Auto. Centric supplies most of the more common auto parts suppliers, so try others if NAPA won't help you.
Everything I've ever gotten from Centric for all my trucks has been of the highest quality and most importantly they fit correctly and perform.
Best regards,
T Herder
T Herder is offline   Reply With Quote
