Old 06-16-2012, 08:51 AM   #1
jackson
spring rate
what lb rear coilover spring are you guys using on your ad trucks
jackson is offline   Reply With Quote
Old 06-16-2012, 09:23 AM   #2
mknittle
mknittle's Avatar
Re: spring rate
I had a hard time getting an answer on that. I am starting with 250 pounds per inch on my 52 GMC. I am going to run a gas tank in back sooo we will see. I should have all the parts made in the next two weeks.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-16-2012, 10:50 AM   #3
bwilli2
Re: spring rate
My shocks from Aldan/Flat-out just came, and looks like 450's for the rears. Unless they had a mix up. They were dropped shipped. I went with the 'recommendation.'
I've pinged Don at Flat-out for clarification just in case. I'll post back what I hear.
51 Chevy 3100 5 Window
Build Thread: http://www.67-72chevytrucks.com/vboa...d.php?t=516689
bwilli2 is offline   Reply With Quote
Old 06-16-2012, 03:23 PM   #4
mknittle
mknittle's Avatar
Re: spring rate
wow 2 X 450 that's 900 pounds per inch! sounds stiff even for the front.
Mark
My GMC build.
Old 06-16-2012, 07:11 PM   #5
booger1949
Re: spring rate
i was told to run 200 in my ad unless i was gonna haul somethin an if i was i was told to use 250
booger1949 is offline   Reply With Quote
Old 06-16-2012, 07:16 PM   #6
jackson
Re: spring rate
i was told the same thing by fab quest
Old 06-16-2012, 09:28 PM   #7
mknittle
mknittle's Avatar
Re: spring rate
that sounds more like it! Then maybe I will be ok with the extra wieght of the gas tank behind the rear end.
Mark
My GMC build.
Old 06-17-2012, 12:37 AM   #8
bwilli2
Re: spring rate
Indeed, something seems 'off' Aldan's site lists much lower rates for street rods and such.
Old 06-18-2012, 01:24 PM   #9
buggy5872
buggy5872's Avatar
Re: spring rate
I am running 250 lb in the rear of a 59 with fleetside bed, steel floor and rear tank. They ride very nice. Not an AD but probably similar in weight
buggy5872 is offline   Reply With Quote
Old 06-18-2012, 08:31 PM   #10
mknittle
mknittle's Avatar
Re: spring rate
Thanks buggy.
Mark
My GMC build.
