Old 06-16-2012, 10:45 PM   #1
SunSoaked
SunSoaked's Avatar
Suspension parts supplier ?
Anybody have a good lead on who sells the bushings and other hardware to overhaul leaf spring packs? I'd like to replace all the rubber bushings and plastic thingys between the leaves. May consider polyurethane and greasable bolts if available. Would I be better off just taking the packs to my local spring shop and having them do it? I have the tools, would rather not have to pay someone for labor.
SunSoaked is offline   Reply With Quote
Old 06-16-2012, 11:13 PM   #2
k5xjfiles
Junior Member
k5xjfiles's Avatar
Re: Suspension parts supplier ?
http://offroaddesign.com/
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker
89 XJ Pioneer, 4.5" 32s.
98 ZJ DD.
Parting..87-01 Cherokees
I bore throttle bodies-PM me for details!
k5xjfiles is offline   Reply With Quote
Old 06-17-2012, 09:39 AM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
As far as spring bushings I use Jegs or Summit.
For the UHMW between the leafs, I buy 1/16 thick sheet and cut my own pieces. You can get it at a plastic supply or McMaster Carr.
The odd size 9/16 hardware are available at Fastenal.
Center bolts you can get at a spring shop or sometimes Jegs/Summit. Although my 64" leafs had a metric center bolt and the spring shop said to use a standard one. That wasn't good enough for me, it was sloppy. So I bought the correct size metric bolt at Fastenal and turned the head down on the lathe.
Here's some spring rebuilding i did last year. http://67-72chevytrucks.com/vboard/s...d.php?t=480181
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
