I know the pieces fit
Bruiser gets some muscle... finally...
This project has been sitting a long time, I haven't driven it in a year. Just starting it up occasionally and keeping it on the battery tender. But I have been collecting parts all the way for an engine upgrade.
Originally, the plan was to get a fresh 350 short block, freshen up the heads, intall a nice cam, aluminum intake, rebuild the Q-jet, and run it. That went out the window a looooong time ago. ![]() ![]() I took the cover off the diff this weekend, the truck has 3.40 gears and the factory Gov-Loc. I ordered some 3.73's and an Eaton Posi to take its place. Before anyone says it, I know I could've installed a 6.0/4L80E for less coin and had more power. But honestly, buying parts has been a slow deal and I passed the point of no return by the time our pioneers here mapped that swap out. No worries, a 383 will fit Bruiser's personality perfectly. This will still be a slow go because I want to detail under the hood before all the shiny parts go in. But it should be turning the drag radials into smoke before too long. Updates coming! ![]() |
Re: Bruiser gets some muscle... finally...
Pics?
The Vic Jr isn't going to give you too much low end. I hope you have at least a 3000 stall converter. A Performer RPM would be a much better intake for a truck that will likely never see north of 6500 RPM, and live most of its life below 3500 (if going to be a street 'Bruiser'). Just my opinion, but I've built many SBC/BBC/LSx combos and they only time mine have received a single plane intake is when all they were doing is blasting down the drag strip or chasing its tail in a circle track car, in other works, not street cars. What are the cam specs? Flat tappet hyd/solid, roller hyd/solid? Regardless, good luck with it!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
Thanks, I appreciate it. Oh, I've got pics.
![]() ![]() This is after the suspension was redone, 2" Ground Force springs up front and 2" (IIRC) Western Chassis shackles in the rear. The original wheel/tire combo was 275/60's on 15x10's all the way around. ![]() Later on the rear tires were replaced with 325/50 drag radials. ![]() The cam is a Comp 274XE, 230/236 @ .050 and .490 lift and of course the lift will be boosted to .523 with the 1.6 rockers. This is a hydraulic flat tappet cam. I know the intake choice is arguable but I will be running a 3000 rpm stall converter, a TCI Street Fighter. The only question is transmission. I know a 700R4 will eventually make it's way into the truck so I went ahead and got the 3.73 gears. I'd like to go ahead and put one in now and not break the budget. I just need to find a good core. I can put that decision off until the motor's buttoned up, so maybe a good core will come up by then. |
#4 | |
what compression is your 383 with those brodix heads? what RPM range are you planning on being with your motor? bigger cam, 9-10:1, no smaller then a 750 carb, that motor will make good power. im jealous!! |
Uh...I'm sorry, but the project name "Bruiser" has been taken and copyrighted by me. Please cease and desist from using the name in any further communications. Thank you.
Just kidding ![]() |
I saw your truck for the first time last week, had no idea we had two Bruiser's here. Beautiful truck, I'll be reading your build thread after work.
Ephesians 2:8
Sharp!
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
Thanks! It's rougher that the camera lets on, but not too bad.
I only thought I was at the front of the line.
![]() The black car got a cam/intake/carb upgrade. But now that all the accessories are out, it'll get cleaned up, painted, and otherwise detailed. So for now the 383 sits in a bag. I did get some seats from Tim Christian here on the forum, and got them installed last weekend. Pictures don't do them justice, I'm tickled to have them. |
I went to fuel it up this evening for the first time in a year. Left driving, came home riding.
Yes we do it for fun; sweating all day, smashed fingers, fuel in the eyes, tired and sore all over..... I LOVE to work on my truck! Good luck with "Bruiser" John!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
#12 | |
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
Thanks man, I appreciate it. I've already got a set of later 80's Blazer/Burb buckets I bought from another member here that I'd planned to install so it was really great to come across a really nice correct set in the correct color. Those seats came with bases, so now I've got an extra set of the K5 seat bases to install in Sarge. They need a little work, the blue vinyl buckets previously in Buiser were not correct and they'd been welded to the seat bases, so those seat bases need a little refurb work before I can reuse them. It's all good, it just takes time - right?
![]() That turquoise 68 pickup is finally done this last weekend. We ended up putting a new motor in and blasting/painting everything we could. It looks great, but it killed a lot of time. And that black Corvette has the new cam installed, but we've still got to detail the engine bay/accessories and button it up. When I started this thread I thought the turquoise truck was done and the Corvette was in the home stretch, putting Bruiser on deck. C'est la vie. I did drop it off for posi/gear install Sunday. Hopefully we'll be pulling the old motor soon. |
'Vette looks like a' 78?
I thought about Bruiser as a name for my crusty old '85 dually, ended up with Fugg & Ugly, my artist son is going to put it on the doors like an old shop truck. Nice Blazer! |
#15 |
Thanks man. The truck was in a buddy's shop for a few days back when the new suspension went on. Most everything got a new coat of satin black, some stuff got painted corporate blue. All that black and blue painting, Bruiser came up and stuck. I'm no artist, but I did free-hand it on the tailgate inspection panel and paint it up, it turned out OK but won't necessarily stay on there.
The Vette is a 78. He's had that car probably 15 yrs now. Hard to tell from that pic but it's a pretty nice car. It's just been under the car cover too long. |
#16 |
I haven't done a thing with the truck. Like I mentioned, I'm having a shop built, and I'm at the point where I've decided to put things on hold until the shop is done. I'd rather wait and do it right the first time, and I won't have the workspace until the contractor is done. Every Saturday I'm working on someone else's project at a friend's shop; I love it - the experience is welcome and so is the money.
![]() Anyway, just an update to explain the lack of updates. I'd rather do everything myself that I can and end up with a 7 out of 10 than try to pay for the best I can afford. |
#17 |
It's not big enough.
I don't care if it's 100' x 100', it's not big enough. Never found a man who built a shop that within a few years didn't say, "I wish I'd have built it bigger". But it's awfully nice to get to work on a concrete floor, out of the weather!!! |
#18 | |
The cam is already in the engine and the compression is 10:1. I've already bought the intake, but not the converter. I have a new vac seconday 750 Holley. I've been talked out of that much converter, now plans are for 2600 rpm stall. I haven't bought the converter yet because I don't know what transmission I'll be running. I hate to rebuild the TH350 when I really want an R4 in there, but I'll have to see how the funds go. I may have to run the TH350 for a while. No big deal except that I'd like to be able to take it out of town once in a while. |
#19 |
truck looks nice! its amazing how much easier it is to do quality work in a shop, not saying nice work cant be done outside its just alot easier with a roof!!
1969 C2500 350/np435 1983 malibu wagon vortec 350/700r4 Gillis |
#20 |
New work spaces are always as exciting as new projects. Hell, post up some pictures of the shop that's being built.
John, are you still going with the single plane high rise intake?..
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear 1966 C10 Fleetside 350 W/ Saginaw 4 speed 1985 K10 Chevy 6.2 diesel 700r4 longbed 2001 Dodge 3500 Dually 24v NV5600 4x4 USMC Reserves Jason |
#21 |
definitely go 14x20, it may not seem like much, but an extra 2' will make a lot of difference. i've got a 24x30 stuffed to the gills...i grew up with a 48'x48' that had hanger doors on it, and a 16' roof height....haha, i miss that shop, you could have 3 projects going at once and still have room to pull in a few others.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#22 |
John, I had a 24x30 shop with 10 foot walls at my house in Mississippi. I miss that a whole lot now, even though it was too small............ I've now got a single car garage as my very own, with a double garage for other work/daily drivers. Go as big as you can!
#23 |
The shop in the previous picture with the Vette is a 10x20 with a 21x20 carport in front of it. It's a little tight but we've been able to do a lot in that spot. Money won't let me go big, but I can swing the 12x20 or 14x20. That friend is about to upgrade to 26x36 w/lift. I'll be able to do more at home but he's always let me use his stuff/space too. Of course I always help him with whatever he has going on, we're always working on something. But I need my own spot, overdue really. Just glad I can finally build something. It won't have water, but will have phone/cable/AC. I just wish I didn't have to wait 90 days. It's too cold to paint, so I'll manage.
#24 |
Nothing to update except that I found some part numbers I thought I should share. I'd planned to run 3" dumped exhaust for a bit, something temporary. But tailpipes have always been in the plan. After a bunch of searching I finally found some 3" mandrel bent tail pipes for a square Blazer. They won't show up on Summit without the part number, but here they are.
http://www.summitracing.com/parts/imo-370120 http://www.summitracing.com/parts/imo-370127 After months of searching I found them on a Bronco forum. No matter, glad to know they are available and I felt compelled to share. Hope these help someone. ![]() |
