06-19-2012, 02:23 PM | #1 |
C-10 Club Member
Plug wires for Hooker headers and HEI
I just installed Hooker Long Tubes on my 69 and the straight plug boots are really close if not touching on a the headers.
I have searched and searched and the only thing I have found is tons of info about Ram Horns and 76+ corvette wires.....not sure if that applies here. What are people with this combo using. I'm thinking I need a 90 degree boot and I would like the wires to be a good fit. I was thinking about ordering these to clean it all up. http://www.summitracing.com/parts/RNM-1101P/
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
06-19-2012, 03:39 PM | #2 |
Re: Plug wires for Hooker headers and HEI
I used 90 degree boots on mine and ran the back two wires on each side under the header, and the front two along the intake and around the front of the engine. But mine were cut to length wires so they were plenty long enough.
71 GMC long bed 70 Chevy short step 71 Chevy K10 long bed |
06-19-2012, 11:56 PM | #3 |
I'll have to double check,but I believe it's '86 heavy GVW 3/4t plug wires you need. They came up over the tubular manifolds
06-20-2012, 12:06 PM | #4 |
C-10 Club Member
That would be great
07-06-2012, 07:39 PM | #5 | |
Real looms: http://www.jegs.com/p/Moroso/Moroso-...48807/10002/-1 http://www.jegs.com/p/Trans-Dapt/Tra...24379/10002/-1 http://www.jegs.com/p/Proform/Profor...02311/10002/-1 They call these looms,but they aren't really. Plug wire routing devices???: http://www.jegs.com/p/Billet-Special...44153/10002/-1 A loom is a device that holds strands apart. Think weaving,that's a loom. You don't want wires running at lengths side by side and you want them up and away from the exhaust manifolds/headers,away from the heat as much as possible. Those billet things get hot and heat the wires,not good. Here are the premium stock (8mm) replacements from NAPA for '76 C20 w/350.: http://www.napaonline.com/Catalog/Ca...244_0065537382
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-07-2012 at 11:01 AM. |
06-20-2012, 09:40 AM | #6 | ||
"I ain't nobody, dork."
You can't use straight boot plug wires with headers. About 99% of the time.
Gary
06-20-2012, 09:54 AM | #7 |
I har to use 45 angled plug end on my leads worked great
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
06-20-2012, 12:07 PM | #8 |
C-10 Club Member
I am making contact in a couple places so they need to be changed.
06-20-2012, 08:57 PM | #9 |
90 deg boots work best also a good set of wire looms and custom make your wires
Fuzzy |
06-21-2012, 12:40 AM | #10 |
06-23-2012, 02:35 PM | #11 |
Shortbed club member
I used the '86 3/4 ton wires like Special-K mentioned.
But you have to check before purchacing some sets come with 2 straight boots, the rest are all 90 deg. boots. They are also too short to run like the picture in Hayhaulers post, You have to run them over the valve covers.
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
06-23-2012, 02:46 PM | #12 |
C/10 junkie
I personally like to run the wire looms, it looks clean and functions perfectly. Also they are only $29.99 shipped on eBay. http://www.ebay.com/itm/390401858116...84.m1438.l2648
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
06-23-2012, 11:03 PM | #13 |
hope these help you out
Fuzzy |
06-23-2012, 11:33 PM | #14 |
Thanks looks better than I thought. I'm running the cheap Hedman headers ,mine look like ;;;;.#6 has to be taken out with a wrench and #1 the plug wire is about 1/8 inch from the header.
06-20-2012, 11:42 PM | #15 |
Hybrid67
Agree and I added accel shorty plugs. They are about $30 or so and come in a set of eight. Run about 1/4" shorter than std plugs.
Keep em' Running! All show.....no go |
06-25-2012, 06:48 AM | #16 |
Those are one type of wire loom that are shown. There are many types of looms. I don't like that type because it puts the wires real close to the heat. I don't mind seeing plug wires and use ones that hold the wires up and away from the heat. And,as mentioned,the HEI wires I suggested won't work with that set-up anyway.
06-25-2012, 08:05 AM | #17 |
I run MSD cut to length wires and run them under the headers and around the back of the block. It's real clean looking. I have this thing about hiding wires of all kinds.
07-06-2012, 01:35 PM | #18 |
I am having this same problem with my Hooker long tube headers, going to try and run them under the headers and up behind the block for a clean look.
07-06-2012, 03:08 PM | #19 |
C-10 Club Member
I ended up purchasing the loops I posted and Accel 8.5 mm wires from the 1986 3/4 ton truck .
Everything worked good but 2 of the wires are a tad short at the back of the valve covers. I also ended up with a new edelbrock fuel line and filter/feed combo.....That was a fun day
07-06-2012, 05:38 PM | #20 | |
07-06-2012, 07:04 PM | #21 |
C-10 Club Member
They worked there just touching the rear of the valve covers.
There won't be any issues but there not 100% perfect. I might be able to swap them with one of the other wires but it was a big gamble to swap when it was already done and in the looms.
07-06-2012, 07:32 PM | #22 |
Gotcha. I am gonna go ahead and go this route. I am going to try the 86 3/4 ton wires with out the bracket and see how it works out , if not them im gonna go ahead and buy that too. Thanks!
07-06-2012, 03:24 PM | #23 |
C/10 junkie
Looks good though.
07-24-2012, 01:16 PM | #24 |
Going to get the 76 C20 3/4 TON from Autozone , Duralast. hope these work. I already have " real " wire looms.
http://www.autozone.com/autozone/par...fier=2762_0_0_ |
