Old 06-21-2012, 10:19 AM   #1
matt75
69 c10 front end rebuild
what all parts are involved in a front end rebuild? Ball joints, a-arm bushings, pitman idler......and such. Id like a complete list so i could order the parts at my leisure. Thanx for any help.
matt75 is offline   Reply With Quote
Old 06-21-2012, 12:11 PM   #2
Lee H
Lee H's Avatar
Re: 69 c10 front end rebuild
Go to the suspension and steering section of your shop/repair manual. It will have exploded views of all the components and detailed how-to's for repair & replacement. Your parts list will come from that in a few short minutes.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-21-2012, 12:58 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Matt aboard from NC....you are on the right track....
ball joints (upper and lower)
control arm shafts (upper and lower)
Tie rods (inner and outer)
adjusting sleeves
idler arm
pitman arm
rag joint (if yours is eaten up)
If you don't have one, I'd install a sway bar too
Check your local auto parts stores for pricing...I've also found that Amazon, Rockauto.com, etc sometimes have better prices for same parts including shipping....
I'd also recommend using high quality parts as well...good luck and have fun!
be sure to get an alignment done once you are done with the remove/ replace
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-21-2012, 03:26 PM   #4
mtnbikeman
Early Classic Enterprises is having a 10% off sale for the front end kit. It is all raybestos professional grade stuff. Im pretty sure they have moog as well. I got my kit on monday. It was $540ish if i can remember. Top quality part and great customer service.
mtnbikeman is offline   Reply With Quote
Old 06-22-2012, 03:35 PM   #5
matt75
Thanks guys!
Old 06-22-2012, 10:09 PM   #6
70cst
70cst's Avatar
Howdy matt75 ...
A great big and from the state of OHIO
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
