Old 05-17-2003, 11:06 AM   #1
Cowboyd
Post Speedometer Ratio Adapter
Long time reader first time poster. Just thought I would pass on a little information. I recently had a 3.73 ring and pinion put in replacing a 3.08 ( also installed an Eaton Posi ) Wooo Hooo!! Anyway my spedometer was off before and the change made it read 81@55 MPH. Thought I could change the speedo gears but I was told I couldn't get that much change. Long story short here is a company that will make any ratio reducer you want.
Leach Enterprises in Crystal Lake, Chicago ILL. ( www.leach-ent.com ) Cost was about $70 plus tax and shipping. I will post again when I get it installed.
79' C10 Short Step 355/TH375 W/3.73 & Eaton Posi 1.5"/3" Drop
What I have I owe to udders!
Cowboyd is offline   Reply With Quote
Old 05-17-2003, 12:27 PM   #2
BigRed
A buddy of mine has one of those adapaters on his truck. He had to take it off as it was leaking constantly. Thanks for the info!
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 05-17-2003, 08:29 PM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
You can get gears that will probably work with your combo of tire size and gear ratio. What I think they meant was that you can't just change the driven gear. You will have to change the drive gear too. Take a look at Swervin Ervin's site here. to get some info. If you need more help, let me know, I've sucessfully done this on about five trucks.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 05-18-2003, 04:32 PM   #4
Cowboyd
Joe
Thanks for the reply. I've seen Mike's info before and thought I could solve the problem with the gear change. But my local GM parts guy told me I couldn't get a large enough driven gear.I sure hope he knew you can change the drive also!! If our speedometers are 1000 revolutions per mile the calculator said ther should be a combo that would work. Anyway to late for that I already orderd the reducer. If it leaks or is still off I'll try changing the gears.
Thanks a lot, Boyd
Old 05-18-2003, 09:16 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Try playing for the closest gear ratios you can with this web site.
http://www.tciauto.com/tech_info/speedo_gears.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-22-2003, 05:43 PM   #6
Cowboyd
TTT
