Old 06-29-2012, 12:00 PM   #1
x1buellist
x1buellist's Avatar
Tru-Ram Exhaust manifold fit?
Any idea if the Tru-Ram exhaust manifold will clear the frame etc on a 66 C10 with a 327
http://www.speedwaymotors.com/Tru-Ra...olds,3823.html
x1buellist is offline   Reply With Quote
Old 06-29-2012, 12:14 PM   #2
MalibuKasey
Artist
MalibuKasey's Avatar
Re: Tru-Ram Exhaust manifold fit?
depends if your motor mounts are in the front or rear location on the frame. If they are in the rear you will be fine. If they are in the front you can make it work... But it has to be a SUPER TIGHT 90 degree bend right out of the Rams horn.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 06-29-2012, 12:30 PM   #3
x1buellist
x1buellist's Avatar
Thanks, can you tell from this picture whether mine are in the front or rear location?
Old 06-29-2012, 12:47 PM   #4
Dinos63
chevy only
Dinos63's Avatar
yes they will fit , there is a picture on my thread they sound nice too
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-29-2012, 12:58 PM   #5
padresag
looks like you are in the rear hole. there should be an open bolt hole just in front of the perch on either side that will line up with the other two that are in the perch, just as if you moved the perch forward it would bolt in there
ron
padresag is offline   Reply With Quote
Old 06-29-2012, 01:01 PM   #6
hopped up
hopped up's Avatar
those are sweet! let us know if you get them and any problems with the fit. i wanna put those on mine too.
hopped up is offline   Reply With Quote
Old 06-29-2012, 01:54 PM   #7
x1buellist
x1buellist's Avatar
Ordered them today. Wasn't really ready to tackle the engine compartment. Been working on the frame and back of the truck but I want to get a new exhaust system installed so I needed to have the manifolds installed for that to happen.
