06-30-2012, 10:34 AM | #1 |
P1336 code
Getting this now on my 01' 5.3l. Not sure why it waited 150 miles to pop up but it won't even clear with an AutoXray scanner. Tried googling this but basically came up with these options...
1. Pay GM at least $100 to do a CASE relearn with a Tech II 2. Spend $600 to get HPtuners or EFILive and do it myself, though it might or might not actually work 3. Buy a $3000 OTC Genesis scanner to do it. Does this sound right? Any other options? I was really hoping there was a handheld tuner out there somewhere that I could use but none of them seem to have CASE learn options. Seems like a ton of money on a 5 minute fix. If anyone has a better idea please let me know. Thanks...Mike
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
06-30-2012, 11:34 AM | #2 |
Truck and auto performance nut
Re: P1336 code
thought there was a way to do it w/o? takes like 30-40 min of key on key off key back on.....
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
06-30-2012, 11:35 AM | #3 |
meowMEOWmeowMEOW
Re: P1336 code
Spend the $150 for the HPT credits and have an HPT tuner in your area do it. At least thats what I'd recommend. Heck if you've ever had it accessed in HPT you arlready payed for the credits, so you just need to kick the tuner some coin for 20min of his time.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-01-2012, 09:26 PM | #4 |
Re: P1336 code
You can definitely turn the code off with HP tuners. I tried to run the case learn with HP tuners, and I believe that would work with the 01. I have an 05 and I couldn't get it to work. So I took it to GM and they couldn't do it either. The issue for me is that the computer has to know that the e-brake is on before it will run the case learn. But the e-brake is connected to the body control computer.....
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-02-2012, 03:55 AM | #5 |
Re: P1336 code
Wish the guy that set my ecm up thought that far ahead and took the code out when he took out the emmisions stuff. Of course that was an ebay guy about two years ago. Is HP easy to use? I don't know squat about tuning and would be afraid to mess it up. I live about 30 minutes from Ed Wright Auto (Fastchip) and have emailed them about this, waiting on a response. It's possible for the same kind of money I can get a performance tune at the same time.
07-02-2012, 12:38 PM | #6 |
meowMEOWmeowMEOW
Re: P1336 code
From what I understand, most of the dyno tuners in OK get a bad wrap. I'm not exactly sure why, but everyone I've talked to drives over to DFW to get their dyno tunes.
07-02-2012, 08:48 PM | #7 |
TruckincrazY
Re: P1336 code
I have this code also. There are a couple of pins that can be grounded to fake the brake signal. Someday I'll get around to doing mine.
My build thread - '84 2wd w/ a 6.0 swap http://67-72chevytrucks.com/vboard/s...d.php?t=433595 |
