Old 05-18-2003, 12:23 AM   #1
72addict
Finally got the 20's on the GMC
Stock suspension. I may bag it later on. I kinda like the stock height for now.
1957 Cameo
72addict is offline   Reply With Quote
Old 05-18-2003, 12:25 AM   #2
72addict
I more
1957 Cameo
Old 05-18-2003, 12:26 AM   #3
72addict
Rear discs look cool thru the windows in the wheels.
1957 Cameo
Old 05-18-2003, 12:29 AM   #4
72gmcshorty
72gmcshorty's Avatar
What kind of rear disk setup is that?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-18-2003, 12:36 AM   #5
72addict
Home grown. 1979 k10 front calipers and brackets(bored holes on brackets to fit rear and redrilled 4 mounting holes to fit bolt pattern on axle) , 1984 delta 88 front hoses (they are short) and late model cherokee front rotors (same bolt pattern 5x5, had to bore the center hole to 3.110 and turn 1/4" off diameter to 11.75). Also removed the factory prop valve.
1957 Cameo
Old 05-18-2003, 12:41 AM   #6
dtlilly
dtlilly's Avatar
Do what? That looks sweet
dtlilly is offline   Reply With Quote
Old 05-18-2003, 01:18 AM   #7
Crank
Crank's Avatar
Um, I love 20's and especially them on your truck, but with stock suspension like that, you could easily fit 22's on there :Evil laugh: your truck needs a bath man, come on. lol. And how long did it take you to set up that brake system man? lol, sounds like you're a junkyard king.
Brandon
Crank is offline   Reply With Quote
Old 05-18-2003, 01:41 AM   #8
Josh292
Sweet, what size tires are those?
Josh292 is offline   Reply With Quote
Old 05-18-2003, 02:03 AM   #9
72addict
Thanks for the kind words. The tires are Goodyear gt2's 275/45/20. I have been accused of enjoying trips to the junk yard a little too much. LOL Actually, my brother (who died a couple months ago) showed me how to use parts books to find over the counter parts for the customizing I seem to always be doing. The paint is original and very weak. I have found that washing the truck just removes more of the paint. LOL I worked on the rear discs for about a weekend. I am a machinist by trade, so boring the holes out was a snap.
1957 Cameo
Old 05-18-2003, 02:41 AM   #10
Alexis
Member since 2000
Alexis's Avatar
Lookin Good Those wheels look great!
Alexis is offline   Reply With Quote
Old 05-18-2003, 01:11 PM   #11
Blue68
Blue68's Avatar
This is not meant to be derogatory, but with the stock suspension, it looks like it's standing on tip-toes.
Looks good.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 05-18-2003, 01:46 PM   #12
72addict
tip toeing thru the mud !! Maybe I should stick to lifted 4x4's? LOL
1957 Cameo
Old 05-18-2003, 05:34 PM   #13
72addict
I removed one coil from front springs with a chop saw. Next, I will install A body rear springs to lower the rear.
1957 Cameo
Old 05-18-2003, 05:38 PM   #14
dons72
dons72's Avatar
Like your tires love those rear discs.Wanna do mine
72 cheyenne super
dons72 is offline   Reply With Quote
Old 05-22-2003, 05:48 AM   #15
72addict
Could someone slam my truck for me in photoshop?
1957 Cameo
Old 05-22-2003, 07:00 AM   #16
ZOOMY
drop
Needs a 4/2.5 drop with those rubber band tires. Not proportionate. You'll agree when they photoshop it for you I think anyway, and I'm not even from Ca.
ZOOMY is offline   Reply With Quote
Old 05-22-2003, 08:22 AM   #17
Zumo
Hot Rods For Life
Zumo's Avatar
Much better.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 05-22-2003, 08:33 AM   #18
griesel72
griesel72's Avatar
looking good, but it does look good slammed
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 05-22-2003, 10:24 AM   #19
JHickson6
I Love This Stuff!
JHickson6's Avatar
LOWER!!!! Needs to tuck a bit of rim, then she'd look trick as hell!
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 05-22-2003, 03:55 PM   #20
72addict
Thanks for your work. I can't tell it has been digitally altered. Do you do that for a living?
1957 Cameo
Old 05-22-2003, 05:07 PM   #21
nightmare
nightmare's Avatar
i thought that all gmc's had leaf spring rear suspensions. that looks like it's got coils. did you put the body on a chevy frame?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-22-2003, 05:09 PM   #22
Zumo
Hot Rods For Life
Zumo's Avatar
Yep
One more: lower with color edit.
Andy
Old 05-22-2003, 06:31 PM   #23
brennecke
brennecke's Avatar
Minor repairs
Never tire of doing what is right II Thess. 3:13
Northeast Missouri
71 LWB original 350 3/speed
Soon to be 500
brennecke is offline   Reply With Quote
Old 05-23-2003, 04:51 AM   #24
72addict
Fresh paint. You are awsome. Maybe I should paint it for real. Thanks again ZUMO
1957 Cameo
Old 05-23-2003, 04:53 AM   #25
72addict
Nightmare, this is original bbc truck with coils, ordered that way for some reason. Makes for easy air bag install I've been told.
1957 Cameo
