Old 07-01-2012, 04:44 PM   #1
NoNeck
NoNeck's Avatar
How To Remove Chrome Windshield Mouldings
I need some tips on the best way to remove the chrome moulding from the windshield gasket on a '70 GMC. I have several tools made just for this purpose, but need to know if the mouldings are pressed in or glued? Is it better to remove them after the windshield is out of the truck? Do I start in the center or the upper edges? This is my first time removing these, so any help will be greatly appreciated.
Thanks, NoNeck
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 07-01-2012, 05:05 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: How To Remove Chrome Windshield Mouldings
Not sure of any tool that will work well for that. Pull the glass and then pull the stainless trim. The stainless has a lip that "locks" in the groove.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-01-2012, 05:32 PM   #3
ole dollor
ole dollor's Avatar
not a 100% on this...but i thought the chrome trim had to come out first, that was what held the rubber to seal the windshield, and hold it in place, every one that i saw put a windshield in did it this way.....but that is what i think...may be wrong....they started in the middle bottom, took off the chrome cover if it had one and pulled the chrome rubber out of the windshield rubber gasket then the shield.....they should be pressed in....
ole dollor is offline   Reply With Quote
Old 07-01-2012, 07:56 PM   #4
cdowns
cdowns's Avatar
not at all//
remove glass and rubber then remove the trim from the gasket
Old 07-01-2012, 09:32 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
You are thinking of the 73-87 windshield rubber.
It has a "zip strip" that helps hold the windshield in.
Keith
Convert to disc brakes.
Old 07-01-2012, 10:59 PM   #6
ole dollor
ole dollor's Avatar
Ok....my bad....
Old 07-01-2012, 11:09 PM   #7
william-theglassman
william-theglassman's Avatar
if you are using a new gasket cut the old one with a utility knife. if you are reusing the old gasket fold the inner lip under and push it out with the glass. dont push too hard .
william-theglassman is offline   Reply With Quote
Old 07-02-2012, 06:40 AM   #8
NoNeck
NoNeck's Avatar
So, the consensus is to remove the windshield, gasket and moulding as one piece. Then, remove the chrome trim.
Should the windshield be reinstalled with the chrome trim in the gasket, or after everything is back in place?
Thanks for all the advice.
NoNeck
Old 07-02-2012, 08:00 AM   #9
cdowns
cdowns's Avatar
the trim goes into the gasket b4 you try installing the window
