55-59 static drop
Can yall show some pics of static drops with the 55-59 body style. I am thinking of dropping mine with a lowered axle. Can you still do the power steering upgrade with a dropped axle?
Heres mine at stock height Thanks, Dave |
Re: 55-59 static drop
I'm not using a drop axle, but I used a somewhat scientific method to determine my ride height. I put a beer can under the step, directly in front of the rear tire. If I crush the can down 25% it will fit under the bottom of the front fender ahead of the door. I'm using coilovers front and rear. I plan to use Google maps to locate speed bumps and plan my trips accordingly.
Trying not to hi-jack but - Chevette, are drop spindles available for the stock 55-59 axle? Any help on where they're available?
#4 | |
#5 | |
Those dropped spindles are for car not truck
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
Beat me to it. They won't work unless you have a 55/57 car front suspension under your truck.
I've seen rumors of dropped spindles for I beam axles but haven't actually see photos of any. A Google search for dropped spindles for I beam axles doesn't bring up any dropped spindle for any model of vehicle with an I beam axle.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 12-07-2012 at 09:47 PM. |
No problem on the hi-jack I think were after the same answers
Posted via Mobile Device |
![]() ![]() Join Date: Nov 2008
Hmmm...anyone know if these drop spindles work okay with after market disc brake conversion kits?
The other thought that occurs to me is that they may be Chinese made and are castings instead of forged pieces and may be subject to catastrophic failure(?) |
I believe they are described as "Forged Two Piece 2in Drop Spindles".
this is a 55-56 panel,im asuming same frame.did a spring under with 1 inch drop blocks on the rear,now the front is a 79 camaro so its low already,nice little rake
ttt
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
