Old 07-02-2012, 11:40 PM   #1
68MoneyPit
fuel supply
Please dont just tell me to go look at the FAQ. if i knew the answer i wouldnt be posting this. I have a 68 with an 04 6.0L. i am assuming from what i have read on here that because there is only one hookup for the fuel rail that i dont need a return line. can i simply run from the internal fuel pump in the tank to any in line fuel filter and then to the fuel rail ? or do i need to get a regulator in line with the filter? if so, before or after the filter? do i just cap the return line fitting on the tank? otherwise is there any reputable shops in the fort worth area that you would recomend ?
68MoneyPit is offline   Reply With Quote
Old 07-03-2012, 12:18 AM   #2
Kim57
Kim57's Avatar
Re: fuel supply
This is what you need. Corvette filter/regulator.
Kim
http://www.ebay.com/itm/Wix-33737-Fu...sories&vxp=mtr
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-03-2012, 08:43 AM   #3
68MoneyPit
Re: fuel supply
what is the inlet fitting? and is that at GM connection on the downstream side or are you just sliding a rubber hose over them that is rated for fuel injection? I assume one of those fittings is a return line off the filter? Built in regulator?
Old 07-03-2012, 11:08 AM   #4
Kim57
Kim57's Avatar
Re: fuel supply
You will need these for the inlet and return lines. Inlet is 3/8 and return is 5/16.
http://www.summitracing.com/parts/RUS-644123/
And one of these for the feed line to the engine.
http://www.summitracing.com/parts/RUS-640940/
Hope this helps.
Kim
My build thread
Old 07-03-2012, 12:46 PM   #5
68MoneyPit
Re: fuel supply
does anyone in fort worth area carry this stuff in stock? I absolutely HATE ordering crap off the internet. it is not a security thing. i just would rather have some kind of human interaction. even if it is just someone handing me something and taking my money
Old 07-03-2012, 10:50 AM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: fuel supply
The inlet fitting is the one on the right/top. The center fitting on top is the return to tank. The outlet is on the bottom. It's a filter/regulator that is originally from a C5 corvette. I've used these on several swaps in the past...but make sure you buy a quality unit. I've had "cheaper" ones that were bad (regulator) out of the box.
Also, DO NOT just slide rubber hose over the fittings. Do it right, and either get the correct push-lock to -6 adapters, or buy some dorman replacement fuel lines and use a compression to -6 adapter.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-03-2012, 10:55 AM   #7
Wasted Income
Boosted Member
Re: fuel supply
Here is how i ran it in my boat
And on a g-body swap i did
Turbo diesel
Old 07-03-2012, 01:56 PM   #8
Kim57
Kim57's Avatar
Re: fuel supply
If you have a good speed shop they may carry some of it. I've also had luck hitting off road/4x4 shops for some things. Pep Boys may have some also. You may have to print out some pics so they know what you're talking about.
Kim
My build thread
Old 07-03-2012, 02:35 PM   #9
OldCreek
OldCreek's Avatar
Re: fuel supply
The filter/regulator is absolutely an over the counter item at any auto supply shop. The fittings will be a little more difficult but some of the better shops may carry what you need. The fuel injection pressure hose is also over the counter at most shops.
And, yes, all of this can be found using the search commands but I'm not sure it's in the FAQ section...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 07-03-2012, 07:25 PM   #10
72gmcshorty
72gmcshorty's Avatar
Re: fuel supply
look for a post i had started on using nylon fuel lines...much cleaner and cheaper...
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 07-03-2012, 08:34 PM   #11
68MoneyPit
Re: fuel supply
i ended up getting the filter at oreillys and went to Speedtech in fort worth. they had the hose in bulk and all the fittings in stock. i didnt do a price comparison between them and jegs but no matter what it is, it is worth it to be able to talk to someone in person and know that you are getting the right parts the first time
