Old 07-03-2012, 05:59 PM   #1
bowhunter65
newbie here. 4x4 frame question.
I just started a frame off restore on a 71 short bed 4x4. I want to disassemble the entire frame, by removing all rivots. this would allow me to blast all hidden areas. Has any one out there done this. If So, Any suggestions if its a good idea or bad idea. I intend to bolt the frame back together with grade 8 stainless bolts.
bowhunter65 is offline   Reply With Quote
Old 07-03-2012, 06:28 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: newbie here. 4x4 frame question.
Use lock tight on all the bolts and hope they don't come loose. That ride might get interesting.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-03-2012, 09:04 PM   #3
liftmeup
stainless bolts = you truck flying apart, drill all holes out to the next larger size as the bolts will be thinner than the rivet bodies, use fine thread bolts with lock nut.(crush type)
lifted, locked, rockin
liftmeup is offline   Reply With Quote
Old 07-04-2012, 03:05 PM   #4
Joesjunk
Joesjunk's Avatar
I sure wouldnt remove anything that is riveted on.......
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 07-04-2012, 03:39 PM   #5
SS Tim
SS Tim's Avatar
X2, Rivets and bolts don't just interchange under shear loads. Grade, type, size, and material are all factors. If this is foreign to you, then your best bet would be to check the bare frame X,Y and Z axis. True and repair as needed then blast and prime it.
SS Tim is offline   Reply With Quote
Old 07-05-2012, 05:46 PM   #6
bowhunter65
Its got some pretty bad rust,in a couple areas. those parts are gonna have to be replaced. I suppose I could just replace those parts. using grade 8 steel bolts with lock washers and loc-tite. I just know theres rust behind those riveted parts, that the blaster cant get to. Thanks For Your opinions
Old 07-05-2012, 05:56 PM   #7
70cst
70cst's Avatar
Hey bowhunter65
to your new internet truck family and from Ohio.
Best of luck as you do your rebuild and don't forget we luv pics
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-05-2012, 06:19 PM   #8
bowhunter65
hey 70cst Thanks for the warm welcome. I made a rookie mistake. didnt take any pictures before starting the tear down. I have taken many Since Then. Will have to get the wife involved as I am computer stupid.
