Old 07-05-2012, 02:48 PM   #1
67 chevy heaven
rubber or poly bushings?
I am in the process of changing all of the bushings out on my 67.
I wanted to get some feedback as to which type bushing I should go with.
I hear that the poly is hard and squeak.
I hear that the rubber ones break down, crack, and deteriorate.
So I wanted to get some opinions here before I make my purchase.
So what do you think??????
67 chevy heaven is offline   Reply With Quote
Old 07-05-2012, 03:27 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: rubber or poly bushings?
I'd do stock rubber for squeek free use alone. Lots of different opinions out there, so it's based on your driving style and doing what you can to not have them squeek if you go poly.
I have poly body mounts (PO installed)...they squeek. I sprayed them with white lithium while loosening and jacking up the body, but I doubt that will last long.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 07-05-2012, 03:45 PM   #3
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Rubber=usually quieter, less harsh/less vibration transmitted
Poly=Tighter handling, last longer
I guess it all comes down to what you are after. In the majority of bushings I have changed, I have gone to poly. I have never had an issue with squeaking, but I lather mine up with grease before installing, although I have been around others and heard their squeaking poly bushings.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 07-05-2012, 04:26 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
My solution. Zerk fittings do wonders. Poly has worked great on all my vehicles otherwise try looking for polygraphite bushing kits or use graphite lube as well.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-05-2012, 07:28 PM   #5
Pro Performance
Pro Performance's Avatar
I say polyurethane, as they will last longer, and have always had good luck with them. There are pro / cons to everything though.
We are a direct Prothane dealer.Their products that are black in color have a slight hint of graphite in them.
Prothane Products for 67-72 C10
Pro Performance is offline   Reply With Quote
Old 07-06-2012, 10:27 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
This is the way you want to go. If you want the durability of polyurethane with out the squeak, use poly-graphite bushing. They are graphite impregnated, and self lubricating. Problem solved...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-25-2012, 09:45 PM   #7
gfreeze1025
gfreeze1025's Avatar
I tried to go to the website... It seems to be down.
Gary
1971 K5 Blazer 350 V8
gfreeze1025 is offline   Reply With Quote
Old 11-26-2012, 01:27 PM   #8
Pro Performance
I just went to the link and it worked. Give it another try and let me know if you have any issues. Sometimes they update the servers and might have clicked on it during that time.
Travis
Old 11-27-2012, 12:45 AM   #9
gfreeze1025
Travis
Travis,
Quick question I noticed that prothane has different part number for 4WD and 2WD trucks. But only one part number for the full kit. Is it universal or is it 2WD or 4WD specific.
I have a K5 (4WD) and want to make sure I get the right parts
Gary
Old 07-06-2012, 01:24 AM   #10
andrewmp6
Rubber will flex a little so it does help smooth out the ride but that flex can hurt handling and it wears out faster.The poly ones are hard so they last a long time flex almost none if you keep them lubed right they don't squeak that bad as some make them out to be.If its my daily driver normal truck i would use rubber if its a weekend ride or trying to make it handle better then i would use the poly ones.
Old 07-06-2012, 09:02 AM   #11
SWAG
Daily driving with urethane bushings isn't harsh at all. Your springs and shocks are supposed to do the work, not the bushings. If you ever carry any weight, tow or like improved handling, urethane is the way to go. If you lube them properly during installation, they don't squeak.
SWAG is offline   Reply With Quote
Old 07-06-2012, 04:11 PM   #12
67 chevy heaven
Thanks to everyone who chimed in with feedback.
I decided to go with the ones mentioned with Pro Performance.
Thanks again guys
Old 11-25-2012, 11:40 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Glad to hear good reviews aabout stuff I just bought
John
1999 Toyota Tacoma 4x4
Old 11-27-2012, 02:05 PM   #14
Pro Performance
That total kit is for the 2wd, but I can put together a kit for the 4wd, no problem. PM Sent.
Travis
