Old 07-08-2012, 12:23 AM   #1
Jayschevy
Yet another header questions for my 71
I've been searching and looking at post about headers for hours now. I've looked so much I've confused myself.
I have a 71 C10 with a 350 5.7 motor with a 350 turbo transmission that was manual but now has a shift kit installed.
I'm bagging the front of my truck and need to know which shorty header will work with my truck without having to modify anything. I need part numbers of headers that have worked for you guys straight out the box and don't interfear with anything else on the truck.
I'm planning on running my exhaust pipe outside the frame just above the frame bottom.
Any help would be appreciated. I need to order my headers ASAP so I can finish my exhaust system.
Jayschevy is offline   Reply With Quote
Old 07-08-2012, 08:36 PM   #2
rocknss
rocknss's Avatar
Re: Yet another header questions for my 71
X2
rocknss is offline   Reply With Quote
Old 07-09-2012, 05:07 AM   #3
502ms
502ms's Avatar
I have been using the Sanderson Shorty headers since December. My truck has 350/th400 and lays frame...pic in my signature.
Get them from Summit for under $300
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 07-09-2012, 11:39 AM   #4
Jayschevy
Do you know the part number for the headers?
Old 02-05-2013, 09:03 PM   #5
502ms
502ms's Avatar
Sorry, missed the question. I know...much later
Best Regards,
Leon M.
Old 07-09-2012, 05:13 AM   #6
502ms
502ms's Avatar
PS - do yourself a favor and get the following, shorty headers especially need this:
-header spark plugs (they have a shorter base/top, but are made for performance and they sell them by application, i.e. 350ci engine
-get a spark plug wire loom that will route the wires away from the tubes on the headers, and keep the boots stationary...trust me, it will save you $$$ in the long run in buying wires every month
Advance Auto sells the plugs, Summit has a great loom that bolts to valve covers. I went a step further and got the braided spark plug wires....doing great so far.
Best Regards,
Leon M.
Old 07-09-2012, 12:25 PM   #7
Jayschevy
Just ordered a set of Hooker headers. 2466HKR. I will let you know how they fit after I install them.
Old 02-05-2013, 12:46 PM   #8
fastcam1
Young gun
fastcam1's Avatar
did you ever install these? if so how do you like the fit? thanks
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 02-05-2013, 01:50 PM   #9
Jayschevy
The fit was great. However it was a little close to the motor mount on the drivers side for some reason. I'm not sure why cause it wasn't close on the pass side. Probably was how my engine was mounted.
Old 02-05-2013, 11:51 PM   #10
fastcam1
Young gun
fastcam1's Avatar
Right on thanks!
Northwest C10's
Cameron sparks
Old 02-05-2013, 12:55 PM   #11
Hart_Rod
Hart_Rod's Avatar
Have you thought about these?
http://67-72chevytrucks.com/vboard/s...d.php?t=562386
Hart_Rod is offline   Reply With Quote
Old 02-05-2013, 01:01 PM   #12
fastcam1
Young gun
fastcam1's Avatar
Originally Posted by Hart_Rod View Post
Ya, I'm looking for a set of headers for a buddy of mine and he's on a tight budget thanks though
Northwest C10's
Cameron sparks
Old 02-06-2013, 03:15 AM   #13
cubber
hedman headers #69010. Shorties made specifically for these trucks. Mine fit great. Jegs has them for around $200. Then use NGK UR5 plugs. short enough to clear, not expensive like header plugs, and last a LOT longer.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 06-12-2013, 05:33 PM   #14
elf w/capital T
Cubber, you have pics of them installed?
elf w/capital T is offline   Reply With Quote
Old 06-13-2013, 12:19 AM   #15
cubber
Sent you a PM. Gonna have to get pics tomorrow.
=MATTHEW
Old 06-13-2013, 03:21 PM   #16
cubber
Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=584546
=MATTHEW
Old 06-13-2013, 07:55 PM   #17
rocknss
rocknss's Avatar
Cubber thanks for the pics!
I just ordered a set from Jeggs and they have them for $161.99, $20 off!!
Old 06-14-2013, 12:18 AM   #18
cubber
Cool! Glad I could help!
=MATTHEW
