Old 07-08-2012, 06:17 AM   #1
kgmunro
Question on disc conversion
If converting the front drum to disc on my 65 is there a 6 bolt rotor from factory that will fit my stock 65 spindle? It is 2wd...
kgmunro is offline   Reply With Quote
Old 07-08-2012, 01:10 PM   #2
cb1965
cb1965's Avatar
Re: Question on disc conversion
No. Your stock spindle is for drums only. You will need to change it if switching to discs. As far as stock 6 lug rotors i believe 88-98?? Will work with the corresponding parts (spindle, ball joints). What i did was switch my front crossmember,73-87, added drop spindles and aftermarket 6 lug 1.25 thick rotors.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 07-08-2012, 02:13 PM   #3
b2948kevin
b2948kevin's Avatar
CB1965 knows more than I do, and I agree with him.
If you're looking to go 6 lug with discs, I did a write up in my build thread vetting several ways to accomplish this. It might give you an idea of the magnitude of work involved here. I am currently in the process of doing this, so if you have questions, PM me.
Check post #215.
66 Chevy C10 Stepside LWB My Build Thread
75 Harley FLH
84 Mercedes 300TD Diesel Wagon
b2948kevin is offline   Reply With Quote
Old 07-08-2012, 02:50 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
What's your reason for running a 6-lug wheel up front?
Stock pre-71 steel wheels won't work with disc brakes.
Keith
Convert to disc brakes.
Old 07-09-2012, 01:38 AM   #5
Captainfab
60-66 Nut
Pretty much everything you need to know about front disc conversions is discussed in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
Even the 2 types of 6 lug front disc conversions.
