05-18-2003, 10:27 PM | #1 |
Crossmember
We've got a 72 chev (V/8 3 on the column)that we're fixing up for a garbage hauler(pretty tough shape). Want to put an automatic in and am wondering if the crossmember for the standard will work for the automatic.
05-18-2003, 10:41 PM | #2 |
NO!
The 3-onthe-TREE has the manual FRONT mount bracket between the frame rails. To mount an auto, you will need the rear mount....these seem to go for about 30bucks. YOU will need to remove the front tranny mount, means grinding rivits. Find the need column shifter and components...Assuming you can find a (dont quote me) 6inch tail shaft TH-350, its pretty much a direct swap. And I am sure what ever I have forgotten, someone will come behind me with more comments... Its really a pretty easy conversion....after u find the parts. GOODluck!!!
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
