Old 07-08-2012, 10:53 AM   #1
mobileortho
mobileortho's Avatar
327 vs 305
I haven't been able to figure out why the exhaust smells so bad on my 327. I bought it years ago from someone who swapped it out for a BBC but he didn't have any issues with it. Not sure how long it sat before I bought it, but I didn't install it for a couple of years later (bought the motor before I found the truck). I stored it covered outside but did notice some water in the oil during the install. I changed it but have noticed a little smoke & a pungent odor. I came across someone who rebuilds early Camaros. He has a 305 out of a 93 Z28 with 40K miles that he wants to trade. I know I can have mine rebuilt, but this is free. Yes, not as much power as the 327 but I'm not planning on racing anyone. What do you think?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 07-08-2012, 12:51 PM   #2
B_Hix
B_Hix's Avatar
Re: 327 vs 305
Not much more work to pull the heads on your 327, install new head gaskets and set those 305 heads on there Depending on you're current pistons/heads would likely raise your compression and get you some more power (down low)...
'49 Chevy 3100; 350/350; 305 H.O. P/P heads; 10.5:1; 370 hp; '75 Firebird clip, rearend & steering column; 7+ year home build
B_Hix is offline   Reply With Quote
Old 07-08-2012, 01:08 PM   #3
74 shortbed 406
Re: 327 vs 305
Don't even consider trading a 327 for a 305...
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
Old 07-08-2012, 01:48 PM   #4
DesertCat
DesertCat's Avatar
Re: 327 vs 305
Trade a tired 327 for a 40k mile 5.0? Free? Sure!
This is an economic win, despite the fact that others will insist the Apocalypse will surely follow if you put a 5.0 in there.
Look, unless you're sentimental about your 327... it is a running core engine worth maybe $150... I know, I just sold two of them last month.
I would trade and enjoy your new engine. You can always build the engine you want but this seems like a good deal to me.
In the end... your truck, your money, your choice
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 07-08-2012, 06:04 PM   #5
Warrens69GMC
Warrens69GMC's Avatar
Re: 327 vs 305
The didn't make a 305 in a camaro in 1993
If it is a 1992 305, then you need a electric fuel pump (no fuel pump lobe/ pushrod hole too small)
If your 327 is a small journal - never been machined block, it can command way more money than a 305 ever could.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-08-2012, 09:56 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
Re: 327 vs 305
Never, don't get me wrong i like 305's, but trade a 327 for one no way. 305s are good motor but are like grass they are everywhere cheap.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-09-2012, 08:35 AM   #7
mobileortho
Re: 327 vs 305
14093627 is the id on back of the motor. I looked it up and it's a 305. If I do the trade, I'll keep the fuel injection. I'm running TPI on the 327 now.
Robert C.
1950 3600
Old 07-08-2012, 11:11 PM   #8
1project2many
Re: 327 vs 305
The later engine has some strong advantages. Roller cam for one, and better seals. Install a set of Vortec 305 heads from an L30 equipped truck and a carby intake and you'll make plenty of power. Downside is it takes a lot to make an impressive 305. Even if you build it to 400 hp, which is impressive on a 305, people still say "Yeah, but it's a 305." And it will require a different flywheel and possibly the electric pump as mentioned above.
If you can locate a 283 crank and an inexpensive set of pistons then you could build a budget 302 with the 327 block. Everyone Ooohs and Ahhs when you say you've got a 302. I bought a set of cast 9:1 pistons pistons from a company in AZ in the early '90s. Can't remember the company I bought them from but the pistons were Hy-Duty brand.
1project2many is offline   Reply With Quote
Old 07-08-2012, 11:49 PM   #9
74 shortbed 406
Re: 327 vs 305
I wouldn't take a 305 if you gave it to me. Maybe a 307. Make a 302 would be cool.
1978 GMC K25
Old 07-09-2012, 12:14 AM   #10
meter swinger
meter swinger's Avatar
Re: 327 vs 305
Put the 305 in and put the 327 in your garage and build it right. Then when you have put the 327 back in sell the 305 and recoup some of your rebuild costs.
I have enough modern fuel injection engines. But heres nothing like the feeling of pressing the button on the dash of my 59 and that 327 jumps to life in an instant. Put the 305 in then youll be motovated to get the 327 rebuilt.
meter swinger is offline   Reply With Quote
Old 07-09-2012, 08:50 AM   #11
jjzepplin
jjzepplin's Avatar
Re: 327 vs 305
I cl'd a running 305 w/roller cam for over two years for $100. Finally gave it away.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
