Old 07-09-2012, 06:18 PM   #1
OSDCrusher
1990 Blazer code 32
Recently the "service engine soon" light came on my 1990 Blazer. I scanned for codes using the paper clip method. I got a code 32 (EGR SYSTEM). So I put in a known good, working, negative backpressure EGR Valve from a different TBI Blazer, which did run good before I pulled the EGR Valve. I drove it around that day with no more SES light. Yesterday I was driving it and the SES light came on again. So I scanned for codes again and got code 32. I have noticed that I have been getting bad gas mileage and a foul smell from the exhaust (which has no catalytic converter present.) The truck also has a new Delphi IAC Valve. The engine runs good and has plenty of power, no hesitation or bucking and the injector spray pattern looks very good.
OSDCrusher is offline   Reply With Quote
Old 07-17-2012, 12:56 AM   #2
OSDCrusher
Re: 1990 Blazer code 32
Fixed the problem myself. Thanks everyone.
Old 07-17-2012, 01:22 PM   #3
rfmaster
rfmaster's Avatar
So what was the solution to your Code 32 problem - EGR related codes are PITA to figure out sometimes.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 07-17-2012, 02:23 PM   #4
OSDCrusher
I replaced the EGR valve, then I reset the ECM. SES light stopped coming on.
Old 08-29-2012, 11:14 AM   #5
Jeepwm69
How do you reset the ECM?
I got a 32 code too. Going to replace the EGR valve and hopefully that will fix it.
Jeepwm69 is offline   Reply With Quote
