Anyone notch their crossmember for a BBC Large Oil Pan?
hello any pics and advice on notching my crossmember to allow for a extra large BBC oil pan would be great....
Edited By Staff "If I had all the money I've spent on Trucks, I'd spend it all on Trucks" |
Still plays with trucks
Re: Anyone notch their crossmember for a BBC Large Oil Pan?
How much notch are you talking? A full length sump dragster type pan or just a Chevelle style pan with the secondary ridge?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
I going with a full length boat style dry sump pan...
The Milodon dry sump on our dragster is deeper than the crossmember and the distance from the pan rail to the crossmember on my stepside with the big block. You would be cutting the stock crossmember in half and having to add depth under the pan so you would end up losing a bunch of ground clearance.
You would be better off building a tubular crossmember to fit around the pan and dry sump lines that will give you the strength you need and maintain good ground clearance. The easy way out would be to run a high capacity wet sump pan instead.
ya I going to have to build me a tubular cross member,,, it's the cleanest way to do it
